916 gearbox conversion kit (915 to 914) |
bugat5speed |
Jan 17 2010, 11:16 AM
Member Group: Members Posts: 92 Joined: 1-August 06 From: Germany Member No.: 6,554 |
Hi altogether, still not on our site (www.bugat5speed.de), but ready for market within the 1st quarter of 2010. 916 gearbox conversion parts. Conversion kit is very near to the OE Porsche 916 kit that was offered in small qty. in the 70s. Kit is with the original 916 OE repro sideshift, mechnical components inside and with a very short nosecone (even 5 mm shorter than OE parts 916). Usage of original exhaust systems is no problem. Complete kit for usage with electronic speedometer will be about 2.100 Euro for export (without VAT). With mechanical speedo drive it will be 2.225 Euro Freight cost to the US about 50 Euro. For more info (upload of pictures is limited here) please send me a PM or better mail to info@bugat5speed.de Martin Bott Bug @ 5-Speed Germany |
bugat5speed |
Jun 12 2012, 11:16 AM
@ Steve: thanks for the infos! I will use an older 915 for my car, as I´m gonna use the 2.2 E engine (MFI) - S-configuration is the aim. If you go 2.7 or bigger it´s anyway better to have the 8:31 combination. In that case I would prefer the aluminium cased 915 although more weight - but also more stabile (just as you did).
@ all: picture shows gearbox with mounted speedo drive. Nuts of nosecone still missing. Have to install the reverse gear switch actuator still. Bolt to fix the speedo has to be turned cause left the socket too high for the original 914 screw. Next batch of nosecones will be milled down there. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:12 AM |
