916 gearbox conversion kit (915 to 914) |
bugat5speed |
Jan 17 2010, 11:16 AM
Member Group: Members Posts: 92 Joined: 1-August 06 From: Germany Member No.: 6,554 |
Hi altogether, still not on our site (www.bugat5speed.de), but ready for market within the 1st quarter of 2010. 916 gearbox conversion parts. Conversion kit is very near to the OE Porsche 916 kit that was offered in small qty. in the 70s. Kit is with the original 916 OE repro sideshift, mechnical components inside and with a very short nosecone (even 5 mm shorter than OE parts 916). Usage of original exhaust systems is no problem. Complete kit for usage with electronic speedometer will be about 2.100 Euro for export (without VAT). With mechanical speedo drive it will be 2.225 Euro Freight cost to the US about 50 Euro. For more info (upload of pictures is limited here) please send me a PM or better mail to info@bugat5speed.de Martin Bott Bug @ 5-Speed Germany |
rhodyguy |
Jan 3 2013, 10:57 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
confused (IMG:style_emoticons/default/unsure.gif) are you aware the way you have your item pricing,
for example, "el. speedo kit: 2.650 US$", reads as two dollars and sixty five cents/ $2.65? not to be picky but if you need to move the decimal point it would then read as $26.50 per or $265.00 or $2650.00. hopes this helps to clarify. k |
ArtechnikA |
Jan 3 2013, 11:06 AM
...are you aware the way you have your item pricing, for example, "el. speedo kit: 2.650 US$", reads as ... Most of the rest of the world uses '.' where US/UK uses ',' and vice-versa. IOW - '.' is thousands separator, ',' is "decimal point. Good to know when interpreting numbers written in other countries... |
Lo-Fi Version | Time is now: 16th May 2024 - 08:38 AM |
