I can fix Outside Door Handles, Much cheaper than new, see pics |
URY914 |
Mar 23 2004, 08:06 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,319 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is your outside door handle broken? Just wait, it will.
Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul Attached image(s) |
swood |
Mar 27 2004, 10:11 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Paul, Does this mean you can fix the flapper/handle too? Tell us more...
Steve |
URY914 |
Mar 31 2004, 06:31 PM
Steve,
I can change out the flapper handle but this is just a replacement that I buy just like you can. It can be replaced while I'm doing the the mounting tab fix. You can buy the flapper and the plastic slider, than send them to me with the broken handle and I'll put it all back together better than new. The mounting tab is the item that breaks and really spells the death of the handle up until now. I have developed a means of repairing the mounting tab. Paul |
URY914 |
Dec 29 2004, 11:39 PM
The flapper handles are no longer sold by Pelican. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) If your flapper breaks, you got a problem. Paul |
dcicchetto914 |
Jan 11 2005, 08:07 PM
Member Group: Members Posts: 74 Joined: 6-December 04 From: San Diego, CA Member No.: 3,230 |
Pelican Parts is not the only place that sells 914 parts, you can also get parts from Performance Magazine , and Tweeks and they both have websites.
Flappers are a dime a dozen, if you go to any 914 dismantling place they will have a crapload of them for dirt cheat. (they also have a crapload of borken doorhandles because they dont understand that there not worth anything.) Drue |
914werke |
Feb 19 2005, 08:13 PM
"I got blisters on me fingers" Group: Members Posts: 10,037 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Paul was it you that was also considering offering these refinished for instance in black chrome or powdercoat?
914werke |
Sep 12 2005, 03:55 PM
Paul, From the Pic Im not sure I understand the fix. T
The problem is that the 8mm post breaks off and the ususall fix is to drill a hole through the body of the handle and use a bolt and nut, which is protrudes into the cavity that you reach behind to pull the flapper handle (does that make sense?) What are you doing in the image? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
URY914 |
Sep 30 2005, 02:53 PM
Let me post a broken handle picture so you can see what happens.
URY914 |
Feb 12 2015, 05:51 PM
I just repaired another handle. This one was for a 914 owner in Sweden.
If you have a few spare handles laying around you should think about getting them repaired. I don't know how long I'm going to keep doing this. (IMG:style_emoticons/default/biggrin.gif) |
jack20 |
Feb 18 2015, 12:44 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I just repaired another handle. This one was for a 914 owner in Sweden. If you have a few spare handles laying around you should think about getting them repaired. I don't know how long I'm going to keep doing this. (IMG:style_emoticons/default/biggrin.gif) My tab broke off, driver side. Looks as though you have machined a new integrated "tab" that bolts into the same space. Am I correct? If so, how can I send my handle to you for repair? Thanks, Jack |
URY914 |
Feb 18 2015, 12:52 PM
Yes that is what I do. I hand fit an aluminum piece that replaces the pot metal tab. I've been doing it for years and have never had one fail on me or returned. I PM'd you my address. (IMG:style_emoticons/default/biggrin.gif)
North Coast Jim |
Dec 12 2015, 08:23 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Is your outside door handle broken? Just wait, it will. Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul I've got two handles that need repair. One is broken and the other is only a matter of time. While their out of the door i's like to get them refurbd. How to get in touch ?? |
URY914 |
Dec 12 2015, 02:41 PM
Is your outside door handle broken? Just wait, it will. Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul I've got two handles that need repair. One is broken and the other is only a matter of time. While their out of the door i's like to get them refurbd. How to get in touch ?? I'll send you a Private Message. |
NeunEinVier |
Dec 29 2015, 05:09 PM
Member Group: Members Posts: 110 Joined: 24-December 15 From: In front of the smoke. Member No.: 19,488 Region Association: None |
URY914 |
Dec 29 2015, 07:04 PM
URY914 |
Dec 29 2015, 07:37 PM
RacingDreamz |
May 16 2016, 03:10 PM
Member Group: Members Posts: 62 Joined: 21-May 15 From: Mountain City, Tn. Member No.: 18,747 Region Association: South East States |
Ury914, Brian Cheney referred me to you about broken handles. I also have a 'broken' pot metal tab on my passenger door. What's your cost to replace that piece. The plastics in the handle is in good shape. Just that metal tab is broke.
mburnley |
Aug 27 2022, 08:06 PM
Newbie Group: Members Posts: 2 Joined: 10-June 21 From: Louisiana Member No.: 25,620 Region Association: South East States |
Is your outside door handle broken? Just wait, it will. Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul Is this something you still do? |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:55 PM |
