I can fix Outside Door Handles, Much cheaper than new, see pics |
URY914 |
Mar 23 2004, 08:06 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is your outside door handle broken? Just wait, it will.
Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul Attached image(s) |
URY914 |
Mar 31 2004, 06:31 PM
Steve,
I can change out the flapper handle but this is just a replacement that I buy just like you can. It can be replaced while I'm doing the the mounting tab fix. You can buy the flapper and the plastic slider, than send them to me with the broken handle and I'll put it all back together better than new. The mounting tab is the item that breaks and really spells the death of the handle up until now. I have developed a means of repairing the mounting tab. Paul |
Lo-Fi Version | Time is now: 17th May 2024 - 11:12 PM |
