I can fix Outside Door Handles, Much cheaper than new, see pics |
URY914 |
Mar 23 2004, 08:06 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,737 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is your outside door handle broken? Just wait, it will.
Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul Attached image(s) |
North Coast Jim |
Dec 12 2015, 08:23 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Is your outside door handle broken? Just wait, it will. Send it to me and I'll fix it better than new. I make a piece that replaces the small mounting tab that bolts to the door. You can see this piece when you look at the handle from the side. The cheap pot metal breaks off and the handle flops around. Pelican Parts sells replacement handles for $204.75!!! I'll fix it and add a new plastic slider (that you provide) for $75.00. Here is a picture of a fixed handle. This handle has the original plastic slider. PM me for address and any questions. Paul I've got two handles that need repair. One is broken and the other is only a matter of time. While their out of the door i's like to get them refurbd. How to get in touch ?? |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:01 AM |
