Tunnel Fuel Line replacement |
swood |
Mar 23 2004, 09:18 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I got the 3/8" steel brake lines, they bend well so I'm not sweating that. But they don't mate up to the 7mm (high pressure) fuel line.
For a 1911 L-Jet, is the 3/8" necessary? Won't 5/16" work ok? I just got to thinking that if the main delivery line is upsized a bit, does it stand to reason that the fuel rails and lines to the injectors need to be bigger? See where I'm going? I could get a bigger rubber line from the 3/8" but then have to neck down again at the pressure regulator. I'm trying to make some progress and I end up with more questions. I thought I'd just order some aluminum or SS line from Summit, but 5/16" and call it a day. Working on the car is not a good way to end a bad day. But I must press on... (IMG:style_emoticons/default/smash.gif) |
JWest |
Mar 23 2004, 09:35 PM
5/16 is fine (fuel supply wise).
tod914 |
Mar 23 2004, 10:41 PM
5/16 is what i used for my tunnel lines too. I think it is just sligthly bigger than 8mm. So, the 8mm inner diameter high pressure lines will fit fine with it.
swood |
Mar 23 2004, 11:09 PM
(IMG:style_emoticons/default/smilie_flagge24.gif) Thanks.
campbellcj |
Mar 23 2004, 11:33 PM
I got the 3/8" aluminum tubing and some tubing-to-AN6 fittings . I redid the rear bulkhead to carb lines with AN6 braided stuff incl. pressure gauge and inline filter and PMO solid fuel bars last weekend. Gonna do the front cell-tunnel section within the next couple weekends.
cork |
Mar 24 2004, 11:17 PM
ground zero Group: Members Posts: 49 Joined: 11-January 03 From: phoenix,az Member No.: 132 |
Chris could you post some pictures, Thanks Mike
Lo-Fi Version | Time is now: 19th May 2024 - 02:30 AM |
