| tomkirkcis |
Mar 13 2010, 06:22 PM
Newbie ![]() Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 |
Wheel stud length? I am confused as to what is the factory stud length. I seem to be finding conflicting info on the internet. I thought the studs were 45mm . Eric recommended 56mm which would make sense for 8 or 10mm spacers. Then I found this add this add on Paragon.
Replace those tired and damaged wheel studs with our new pieces or increase the length for use with spacers. Here's a basic list of sizes used as original: 45mm - 944 83-86, 924S (front); 924S, 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (rear) 50mm - 944 85.5-89, 944S, 944S2, 944 Turbo, 968 (front) 52mm - 911 65-89 (front and rear) 66mm - 911 Turbo 76-89 (front) 66mm - 944 83-85.1 (rear w/factory spacer) 72mm - 911 Turbo 76-89 (rear) A 914-6 isn't listed but I would think it should be the same as a 911 Anyone know for certain what is the original stud length on a 914-6? Thanks Tom |
| tomkirkcis |
Aug 12 2010, 07:01 PM
I have had a chance to drive the car a couple hundred miles and everything is working out great. The tire fitment is very tight, but no rubs. The car handles so much better with the bigger rubber and the combination of 225's and the LSD has not resulted in any tire spin.
I have not had the car on the track |
| qa1142 |
Aug 13 2010, 04:44 AM
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
First, I want to say this thread rocks (IMG:style_emoticons/default/aktion035.gif) just what I have been needing.
So, I will find out soon if my 15X6 and 15X7 cookies will fit narrow body or not I still want 2nd set of rims with "R" rubber for autoX and track days. Mine is only 2.0L 4 banger so I don't need to over tire, but don't want to under tire either. 16X6 enough? 16X7? Sounds like you have all done this before do I head for 944 section on Pelican to find these rims? Thanks Will |
| Bleyseng |
Aug 13 2010, 09:52 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I had fittment issues in the back with 15x7 cookies but I fixed that (IMG:style_emoticons/default/smash.gif)
that was with 205x50 Kumho's for AXing. Now I am running 16x6's and 205x50x16's without any problems, its nice. |
| qa1142 |
Aug 13 2010, 11:45 AM
so these won't fit with 23 offset with?
Size 15x7 Part Numbers 7JX15 911 361 023 8K A1 S1 12 MG PTL2001 83 ATS Need to be more like "R" with 36 to 49 offset? |
| sixnotfour |
Aug 13 2010, 11:51 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,060 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
Here you go , bolt on , be happ, and light in the wallet
http://cgi.ebay.com/ebaymotors/69-73-Porsc...sQ5fAccessories |
| Bleyseng |
Aug 13 2010, 12:33 PM
and real deep dish rims to boot!!
| tomkirkcis |
Aug 13 2010, 04:43 PM
First, I want to say this thread rocks (IMG:style_emoticons/default/aktion035.gif) just what I have been needing. So, I will find out soon if my 15X6 and 15X7 cookies will fit narrow body or not I still want 2nd set of rims with "R" rubber for autoX and track days. Mine is only 2.0L 4 banger so I don't need to over tire, but don't want to under tire either. 16X6 enough? 16X7? Sounds like you have all done this before do I head for 944 section on Pelican to find these rims? Thanks Will 15 x 7 cookies do NOT fit on a narrow body without massaging the sheet metal. The R wheels fit with the right spacers, but are very expensive (4k a pair). I think some of the Boxter wheels are similar offsets as the R and are available at a reasonable price. They would also need spacers and as everyone has pointed out, each of these cars are a little different and fitment is a car by car ordeal. Good luck |
| qa1142 |
Aug 14 2010, 12:16 PM
This chart help me when I was trying to decide when switching from 14" x 5.5" fuchs to 16 x 6 fuchs on a /6. There are so many factors since there are some wide 205's. So 911R with 27 mm spacer is just about equal to 911.361.020 if I figure that right. Am I correct? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 8th December 2025 - 11:03 AM |
