Muffler Bracket Hangers?, Heat Exchanger does not line up? |
Vysoc |
Jan 31 2010, 01:15 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello, I am hoping this is a fairly straight forward situation with a hanger that I do not have or just a simple fabrication of a couple of additional brackets. Last night while attempting to watch the 24 Hours of Daytona, we were installing my Stainless Heat Exchangers, several of the original Exhaust studs were broken and replaced but several were slightly offset when they were reinstalled. It was really a PIA getting things bolted back up due to the obvious clearance issues with the exhaust bolts. So when fitting up the muffler bracket on the transmission things are off as you can see in the pictures, heat exchangers hang down about 2 inches. Am I missing a hanger or should I just fabricate a couple of pieces of steel. The actual muffler lines up just fine to the six holes.
Thank you, Vysoc (IMG:style_emoticons/default/sawzall-smiley.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:21 PM |
