Need brakes?, It doesn't get any better than this |
koozy |
Feb 1 2010, 04:45 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I just had to post my experience with Eric at PMB.
Fantastic service and top notch products. I had an issue with calipers I got from someone else. Went to put them on and saw they needed to be machined on the ears to work properly. Crud... These are for a race car so the best is all I could want for the brakes. Called Eric and he said he had a set fresh from plating and he would rebuild them "right now" and send them out in the morning. BTW: This was after 8pm my time and later in his neck of the woods. Later on in the evening I found that I misplaced the pad springs for the rears and sent him an email or left a message on the voicemail (can't remember which). I figured it was a bit late for the springs to get sent so I wrote that part off. Just got a set of front M calipers from the mailman and low and behold... rear pad springs in the box... freshly rebuilt calipers, better than stock pistons.. etc... I can go on but it would sound like I have a crush on Eric, sooooo.... A big "THANK YOU" You want the best??? Go with PMB. Mike |
McMark |
Feb 1 2010, 04:51 PM
ConeDodger |
Feb 1 2010, 04:57 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I just had to post my experience with Eric at PMB. Fantastic service and top notch products. I had an issue with calipers I got from someone else. Went to put them on and saw they needed to be machined on the ears to work properly. Crud... These are for a race car so the best is all I could want for the brakes. Called Eric and he said he had a set fresh from plating and he would rebuild them "right now" and send them out in the morning. BTW: This was after 8pm my time and later in his neck of the woods. Later on in the evening I found that I misplaced the pad springs for the rears and sent him an email or left a message on the voicemail (can't remember which). I figured it was a bit late for the springs to get sent so I wrote that part off. Just got a set of front M calipers from the mailman and low and behold... rear pad springs in the box... freshly rebuilt calipers, better than stock pistons.. etc... I can go on but it would sound like I have a crush on Eric, sooooo.... A big "THANK YOU" You want the best??? Go with PMB. Mike You too??? I just have the biggest crush on him (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) Anyone else needing PMB rebuilt M calipers - I have a set I bought from Eric and did not use. I used the aluminum Brembos instead. PM me... |
turnaround89 |
Feb 1 2010, 05:43 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
wertygrog |
Feb 1 2010, 08:49 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
Agreed!!
6freak |
Feb 1 2010, 10:45 PM
I can stop 2 P now (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 07:18 PM |
