I just had to post my experience with Eric at PMB.
Fantastic service and top notch products. I had an issue with calipers I got from someone else. Went to put them on and saw they needed to be machined on the ears to work properly. Crud... These are for a race car so the best is all I could want for the brakes. Called Eric and he said he had a set fresh from plating and he would rebuild them "right now" and send them out in the morning. BTW: This was after 8pm my time and later in his neck of the woods. Later on in the evening I found that I misplaced the pad springs for the rears and sent him an email or left a message on the voicemail (can't remember which). I figured it was a bit late for the springs to get sent so I wrote that part off. Just got a set of front M calipers from the mailman and low and behold... rear pad springs in the box... freshly rebuilt calipers, better than stock pistons.. etc... I can go on but it would sound like I have a crush on Eric, sooooo....
A big "THANK YOU"
You want the best??? Go with PMB.
Mike
