How do you mount your race seat? |
fasthonda |
Feb 9 2010, 05:01 PM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I plan on using a Kirkey aluminum road race seat. Is it feasible to bolt the stock sliders to the seat bottom and use the stock seat rails? Anyone have experience with this? Recommendations on seats or mounting setups?
Please post pictures of your setups. Thanks in Advance, Michael |
J P Stein |
Feb 9 2010, 06:17 PM
Yes, it's doable. You'll need to bolt a plate (3/16-1/4 innch Al.) to the bottom of the seat and then bolt the rail to the plate....
These pics aren't to good .... I took no details of it, but there's enuff here to get the idea across. You might get Brit to take summorebetter ones. BTW, Hondas are slo. (IMG:style_emoticons/default/poke.gif) Attached thumbnail(s) |
john rogers |
Feb 9 2010, 09:56 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I mounted the one I had in the race car solid and it got me about 1 1/2 inches lower which took some getting used to. I did not like the feel of the seat moving due to the mounts. There are some picts in a tech article on the Pelican site.
jhadler |
Feb 10 2010, 12:38 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
John,
Did you remove the cross bar on the floor to mount your seat? I see that as the biggest impediment to a solid mount. I'd love to be able to mount my seats (Corbeau Forza) on some kind of slider, and still get them lower. -Josh2 |
john rogers |
Feb 10 2010, 04:13 PM
I did not remove the cross box section. I wanted to keep the strength it provided across the floor. The seat I used had a dual piece bottom so the rear part sat on the floor and the front angled part essentially sat on the box section. I never liked the feeling of movement with any of the movable seats I tried and I felt much more solid once the aluminum seat was bolted down. Since I was an old guy, it was a bit hard getting in and out so that forced me to get the steering wheel removable which turned out great. One thing I did eventually that was not in the article was to lower the steering column mount at the bottom of the dash by about an inch since before that the wheel always felt too high.
EdwardBlume |
Feb 11 2010, 10:55 PM
I used a stock slider with a Kirkley seat. The stock pivot points were gone.. so I just bolted them through the floor with massive washers... the seat is low, so I still have problems seeing over the Ginther screen....
grantsfo |
Feb 11 2010, 11:21 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I used a stock slider with a Kirkley seat. The stock pivot points were gone.. so I just bolted them through the floor with massive washers... the seat is low, so I still have problems seeing over the Ginther screen.... LOL! And I poked up so high I had and extension welded on the cage. |
J P Stein |
Feb 12 2010, 09:06 AM
I used a stock slider with a Kirkley seat. The stock pivot points were gone.. so I just bolted them through the floor with massive washers... the seat is low, so I still have problems seeing over the Ginther screen.... The driver's side is mounted similar to the Pass. side in the pic.....but I raised the bak of the guide up about an inch & a quarter in orer to see over the screen......it's all welded in. |
e30driver |
Feb 18 2010, 08:44 AM
Newbie Group: Members Posts: 4 Joined: 18-February 10 From: Athens, GA Member No.: 11,374 Region Association: South East States |
I have a fiberglass seat I am thinking of using in...a 914 that I WILL get, I've mounted tons of other seats in other cars but this is a bare fiberglass seat, is there a special way to mount this?
ready2flyfish |
Feb 25 2010, 08:07 PM
Newbie Group: Members Posts: 5 Joined: 9-November 07 From: Pennsylvania Member No.: 8,312 Region Association: None |
I have a fiberglass seat I am thinking of using in...a 914 that I WILL get, I've mounted tons of other seats in other cars but this is a bare fiberglass seat, is there a special way to mount this? weld-in steel race seat brackets ESPECIALLY if you do any competition. I use Cobra race seats exclusively and they are Kevlar shells (stronger than FG) and mount exactly as you would a FG seat. Sparco and Cobra make very good weld-in brackets. |
campbellcj |
Mar 1 2010, 11:29 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have the Cobra Suzuka kevlar seats. They are mounted on Cobra side-mount brackets, which give some adjustability via different holes you can use to attach the seat on the front and rear. I can't weld (yet) so they are bolted to the floor using robust hardware and I reinforced the mounting surfaces with flat steel stock for good measure. I cut out part of the cross-brace on the floor, just where the seat brackets needed to go.
This setup is very sturdy and I've been happy with it, although if/when I learn how to weld I will at least weld the steel reinforcements and possibly the actual brackets to the floor. |
Lo-Fi Version | Time is now: 29th April 2024 - 09:22 AM |
