ground connection, grd. cable to volt. reg. board |
kwtruck |
Feb 15 2010, 09:06 PM
Newbie Group: Members Posts: 14 Joined: 27-January 10 From: cropwell, al. Member No.: 11,294 Region Association: None |
where does ground cable connect at the voltage reg. board ?
ejm |
Feb 16 2010, 05:47 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
There is no ground cable connected to the relay/voltage regulator board. If you mean the cluster of ground wires coming out of the harness, that goes onto a stud below the board.
kwtruck |
Feb 16 2010, 07:22 AM
there is a single ground cable from the chassis harness to the voltage reg. board area. it is shown on all the ground connection charts but not specific on what it connects to. the voltage reg. board is mentioned in its discription but I cant find a place in that area for attachment.
rnellums |
Feb 16 2010, 10:27 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I just ran a lead from the cluster connection ejm is talking about behind the relay board to one of the screws that holds the voltage regulator on. everything seems to work of for me, but I dont have EFI anymore either, maybe that matters.
Cap'n Krusty |
Feb 16 2010, 10:32 AM
I just ran a lead from the cluster connection ejm is talking about behind the relay board to one of the screws that holds the voltage regulator on. everything seems to work of for me, but I dont have EFI anymore either, maybe that matters. Congratulations! You've attached a ground lead to plastic! Not gonna be of much use, though. The Cap'n |
76-914 |
Feb 16 2010, 11:01 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I just ran a lead from the cluster connection ejm is talking about behind the relay board to one of the screws that holds the voltage regulator on. everything seems to work of for me, but I dont have EFI anymore either, maybe that matters. Congratulations! You've attached a ground lead to plastic! Not gonna be of much use, though. The Cap'n (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) |
kwtruck |
Feb 16 2010, 05:51 PM
I found it!! A stud on body panel next to relay board covered in undercoating and practicly invisible, especialy someone with poor eyesight.
Lo-Fi Version | Time is now: 23rd May 2024 - 07:52 AM |
