DELETE |
DELETE |
Chevota79 |
Feb 16 2010, 11:30 AM
Member Group: Members Posts: 83 Joined: 11-September 07 From: Rocklin, CA Member No.: 8,113 Region Association: None |
DELETE
Chevota79 |
Feb 23 2010, 08:54 AM
$2000
Chevota79 |
Feb 25 2010, 08:47 AM
Chevota79 |
Feb 25 2010, 08:49 AM
Chevota79 |
Feb 25 2010, 08:51 AM
Chevota79 |
Feb 25 2010, 08:52 AM
Chevota79 |
Feb 25 2010, 08:53 AM
Chevota79 |
Feb 25 2010, 08:54 AM
Rifleman |
Feb 28 2010, 11:50 PM
Newbie Group: Members Posts: 2 Joined: 3-February 10 From: WA State Member No.: 11,320 Region Association: None |
Hey Josh - Do all the lights/electrical function? Brakes work? Any chipped/broken glass? Shift okay? Thanks. |
Chevota79 |
Mar 1 2010, 08:59 AM
Shift pretty good for a 914 all the lights work but needs a flasher relay for the turn signals, and needs a front windshield as there is a larger crack running across it. Brakes work great also
Rifleman |
Mar 2 2010, 10:42 PM
Shift pretty good for a 914 all the lights work but needs a flasher relay for the turn signals, and needs a front windshield as there is a larger crack running across it. Brakes work great also Hey Josh - Do all the lights/electrical function? Brakes work? Any chipped/broken glass? Shift okay? Thanks. Thanks. It looks like the heater is not connected - is that correct? Is appears that the car still has the original fuel injection - is that correct? I probably need to call you - is there a time when my call would not be disruptive? Thanks. |
Chevota79 |
Mar 3 2010, 10:11 AM
Heater controls are hooked up and works but need new ducts from the fan to the heat exchangers. I had some dryer duct on there for a while but recently took it off. Car does have the original fuel injection on it but I do have a single progressive Webber setup for it also. You can pretty much call me anytime before 10 or so at night.
Thanks |
Chevota79 |
Mar 10 2010, 01:28 PM
Still have it. Need it gone
Lo-Fi Version | Time is now: 13th May 2024 - 10:38 PM |
