Setting up to bench test 2.0 engine, Need some help with engine wiring |
LotusJoe |
Feb 18 2010, 09:43 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I have built an engine stand for my 1973 2.0 engine. I'm in the process of trying to wire everything up to start the motor. Can anyone help me out with the what wires I need to supply power to the control module?
(IMG:http://photos-e.ak.fbcdn.net/hphotos-ak-snc3/hs180.snc3/20736_1346662951457_1377807605_959608_6834010_n.jpg) (IMG:http://photos-d.ak.fbcdn.net/hphotos-ak-snc3/hs200.snc3/20736_1346663111461_1377807605_959612_7956026_n.jpg) (IMG:http://photos-c.ak.fbcdn.net/hphotos-ak-snc3/hs180.snc3/20736_1346662991458_1377807605_959609_5643660_n.jpg) This photo show a small group of wires that plugs onto the module and then to (I think various locations on the engine). Looks like a pair goes to the back-up switch on the transmission, but I'm not sure about the rest of them. Any help is greatly appreciated Thanks Joe ( The Newbie to the 914 world) |
detoxcowboy |
Feb 18 2010, 10:21 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I am unsure whihc year 2.0 you have and which harnesses your trying to reconnect but at the bottom of this link you will see link to all the harnesses and all the style's with diagram of which wire leads to which componet from the "module"? by module I am assuming you mean the relay board?
by the jump wire on your ignition harness I am going to gues you have a '74 2.0 or 75-76 http://bowlsby.net/914/WiringHarnesses/ |
detoxcowboy |
Feb 18 2010, 10:27 PM
LotusJoe |
Feb 18 2010, 10:38 PM
I'm unable to get that link to work. Think maybe the site is gone??? But thanks for the input
LotusJoe |
Feb 18 2010, 10:41 PM
Thanks detoxcowboy for the drawing. That takes care of the engine side of things. Now all I need to know is which pins on the relay board need power so I can start the engine up.
detoxcowboy |
Feb 18 2010, 10:42 PM
I'm unable to get that link to work. Think maybe the site is gone??? But that for the input start here.. http://members.rennlist.com/914_wiring_harnesses/ or you can google jeff bowlsby wire harness and you will find it.. jeff is a member here whom amoung many attributes makes and sell wire harness for all 914's.. excellent quaility highly recomended.. therre is your pitch Jeff you pictures your handiwork, i just cut and paste baby.. |
LotusJoe |
Feb 19 2010, 01:47 AM
Thanks, I got the link to work. Now I only need a diagram of the 14 pin connector on the relay board. I sent Jeff an email for the information. Hopefully he has laid that one out. His work look outstanding. I'm definitively, going to use his service when it comes time for the car to go back together.
Thanks again |
Cap'n Krusty |
Feb 19 2010, 09:18 AM
Or you could just look at the factory wiring diagrams over on the Pelican Parts site ............
The Cap'n |
type47 |
Feb 19 2010, 09:21 AM
factory wiring diagrams over on the Pelican Parts site ... http://www.pelicanparts.com/914/914_electrical_diagrams.htm |
jcd914 |
Feb 19 2010, 11:13 AM
Here is what I have for the 14 pin connector for the Relay Panel.
1 - Power in from starter switch 2 - Power/ground for Alternator light 3 - 4 - 5 - From Oil Press Light 6 - 7 - Signal to Tach 8 - Power in from Ignition switch 9 - To Heater Fan Switch 10 - To Main Ground 11 - Power out to Heater Fan 12 - Power in from Battery 13 - Power out to Fuel Pump 14 - Power in from Battery Jim |
LotusJoe |
Feb 19 2010, 12:09 PM
Here is what I have for the 14 pin connector for the Relay Panel. 1 - Power in from starter switch 2 - Power/ground for Alternator light 3 - 4 - 5 - From Oil Press Light 6 - 7 - Signal to Tach 8 - Power in from Ignition switch 9 - To Heater Fan Switch 10 - To Main Ground 11 - Power out to Heater Fan 12 - Power in from Battery 13 - Power out to Fuel Pump 14 - Power in from Battery Jim Thanks Jim, that's exactly what I was looking for. Now I can finish the wiring for the engine stand. |
LotusJoe |
Feb 19 2010, 04:53 PM
LotusJoe |
Feb 25 2010, 08:09 PM
Thanks to all who responded on this thread. The engine is completely wired and running on the bench. Engine seems to run strong even after having sat for almost 10 years. Starts right up, idles good, good throttle response.
Again thanks to everyone. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 02:00 PM |
