spark plug type for 1.7, confused about different types |
jeremiah98125 |
Feb 18 2010, 10:39 PM
jr Group: Members Posts: 37 Joined: 11-November 09 From: seattle, wa Member No.: 11,031 Region Association: Pacific Northwest |
So I've been reading through all the posts about spark plugs and still confused. What is the right type for my 1.7? My owners manual says to use Bosch W175 T2 so I was wondering what the modern equivalent is? My car has W8CC and the ones I bought from Pelican are WR7CC which sounds like a hotter plug with a resistor?
TheCabinetmaker |
Feb 19 2010, 07:35 AM
NGK BP6ES is what I use in all my 914's. They have a new # now, but I don't know what it is.
Cap'n Krusty |
Feb 19 2010, 09:12 AM
There are 2 "correct" spark plugs. NGK B6ES is a good choice, and Bosch W7CC is, too. The resistor plug, WR7CC will work fine. W8CC and it's variants are one heat range step hotter, and should be fine. They were stock on the '76-'79 VW bus, and may be a better choice for modern fuel. If most of your driving is high speed "touring", I'd stick with the first two choices. NO Platinum plugs! All stock 914s use the same spark plug, and the extended reach plugs (B"P"6ES and WR7"D"S) are NOT recommended.
The Cap'n |
edwin |
Feb 22 2010, 08:41 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
not sure if this has been covered before but why not use Platinum plugs?
cheers, edwin |
underthetire |
Feb 22 2010, 09:56 AM
ericread |
Feb 22 2010, 12:17 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
not sure if this has been covered before but why not use Platinum plugs? cheers, edwin Take a look at this posting: http://www.914world.com/bbs2/index.php?sho...ark++plug++heat The last post is mine. I'm in the process of providing a more in-depth write-up. Should be ready within the week. Eric |
914Mike |
Apr 1 2011, 01:06 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
There are 2 "correct" spark plugs. NGK B6ES is a good choice, and Bosch W7CC is, too. The resistor plug, WR7CC will work fine. W8CC and it's variants are one heat range step hotter, and should be fine. They were stock on the '76-'79 VW bus, and may be a better choice for modern fuel. If most of your driving is high speed "touring", I'd stick with the first two choices. NO Platinum plugs! All stock 914s use the same spark plug, and the extended reach plugs (B"P"6ES and WR7"D"S) are NOT recommended. The Cap'n Man, I thought I was going to have to search all day to find out the difference in W7CC and WR7CC. Here it is all in the first thread I found! Thanks Cap'n! Keep it Krusty! (Running out to put the W7CC's in...) |
Lo-Fi Version | Time is now: 13th May 2024 - 10:52 PM |
