QUOTE(Cap'n Krusty @ Feb 19 2010, 08:12 AM)
There are 2 "correct" spark plugs. NGK B6ES is a good choice, and Bosch W7CC is, too. The resistor plug, WR7CC will work fine. W8CC and it's variants are one heat range step hotter, and should be fine. They were stock on the '76-'79 VW bus, and may be a better choice for modern fuel. If most of your driving is high speed "touring", I'd stick with the first two choices. NO Platinum plugs! All stock 914s use the same spark plug, and the extended reach plugs (B"P"6ES and WR7"D"S) are NOT recommended.
The Cap'n
Man, I thought I was going to have to search all day to find out the difference in W7CC and WR7CC. Here it is all in the first thread I found!
Thanks Cap'n! Keep it Krusty!
(Running out to put the W7CC's in...)
