spark plug type for 1.7, confused about different types |
jeremiah98125 |
Feb 18 2010, 10:39 PM
jr Group: Members Posts: 37 Joined: 11-November 09 From: seattle, wa Member No.: 11,031 Region Association: Pacific Northwest |
So I've been reading through all the posts about spark plugs and still confused. What is the right type for my 1.7? My owners manual says to use Bosch W175 T2 so I was wondering what the modern equivalent is? My car has W8CC and the ones I bought from Pelican are WR7CC which sounds like a hotter plug with a resistor?
Cap'n Krusty |
Feb 19 2010, 09:12 AM
There are 2 "correct" spark plugs. NGK B6ES is a good choice, and Bosch W7CC is, too. The resistor plug, WR7CC will work fine. W8CC and it's variants are one heat range step hotter, and should be fine. They were stock on the '76-'79 VW bus, and may be a better choice for modern fuel. If most of your driving is high speed "touring", I'd stick with the first two choices. NO Platinum plugs! All stock 914s use the same spark plug, and the extended reach plugs (B"P"6ES and WR7"D"S) are NOT recommended.
The Cap'n |
Lo-Fi Version | Time is now: 17th May 2024 - 03:51 PM |
