911 speedometer, Electronic Model |
914coop |
Feb 20 2010, 12:27 PM
Member Group: Members Posts: 214 Joined: 5-September 08 From: Minneapolis Member No.: 9,514 Region Association: Northstar Region |
Looking to install a Geety Dash with the 911 gauge cluster, Found a set of 911 gauges for this however the speedometer is a electronic model. I have seen the sensor assembly sold on eBay however I have no idea if it will work on my 914 or how to mount it. Wondering if anyone else has did this?
gopack |
Feb 20 2010, 12:29 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
As far as I know, the 911 and the 914 speedos are the same size. I just transfered my 914 speedo into the Getty dash.
dr914@autoatlanta.com |
Feb 20 2010, 02:02 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Looking to install a Geety Dash with the 911 gauge cluster, Found a set of 911 gauges for this however the speedometer is a electronic model. I have seen the sensor assembly sold on eBay however I have no idea if it will work on my 914 or how to mount it. Wondering if anyone else has did this? Not worth going through the tremendous hassle of rigging an electronic speedo unless you have a 915 gearbox converted into a 914 with wevo or vellious rear cover shift rod conversion. Then you would have to install magnets on the ring gear and drill a hole in the side of the cover and glue in a magnetic pickup!!!!! just use the angle drive and the cable and the original 914 instrument. |
marks914 |
Feb 20 2010, 03:06 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Yes, I would either use the stock speedo or use a programmable electronic one like we make. The stock 911 speedo will not be accurate.
Mark |
914coop |
Feb 20 2010, 07:40 PM
Steve |
Feb 21 2010, 10:58 AM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Yes, I would either use the stock speedo or use a programmable electronic one like we make. The stock 911 speedo will not be accurate. Mark How much is your programmable electronic speedometer? Any where I can see pictures and get details? The link with pricing is in his thread. www.newvintageusa.com |
Lo-Fi Version | Time is now: 19th May 2024 - 08:31 PM |
