QUOTE(914coop @ Feb 20 2010, 11:27 AM)
Looking to install a Geety Dash with the 911 gauge cluster, Found a set of 911 gauges for this however the speedometer is a electronic model. I have seen the sensor assembly sold on eBay however I have no idea if it will work on my 914 or how to mount it. Wondering if anyone else has did this?
Not worth going through the tremendous hassle of rigging an electronic speedo unless you have a 915 gearbox converted into a 914 with wevo or vellious rear cover shift rod conversion. Then you would have to install magnets on the ring gear and drill a hole in the side of the cover and glue in a magnetic pickup!!!!! just use the angle drive and the cable and the original 914 instrument.
