CV spacers, did anyone check them on the outside? |
tat2dphreak |
Feb 22 2010, 12:00 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
on the rear outer CVs(were mounted before we started) I just thought of something(well, at 7am I thought of it, but I just got out of bed)... they need to check and make sure the outer ones have the bolt spacers... Dr. Evil put the 4 spacers on the transmission CVs, but we didn't check the outside ones, since they were already mounted.
if they are left off, the bolt will rub the trailing arm and eventually lock up. this woke me up at 7am... (IMG:style_emoticons/default/smile.gif) |
rick 918-S |
Feb 22 2010, 03:10 PM
Hey nice rack! -Celette Group: Members Posts: 20,435 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
on the rear outer CVs(were mounted before we started) I just thought of something(well, at 7am I thought of it, but I just got out of bed)... they need to check and make sure the outer ones have the bolt spacers... Dr. Evil put the 4 spacers on the transmission CVs, but we didn't check the outside ones, since they were already mounted. if they are left off, the bolt will rub the trailing arm and eventually lock up. this woke me up at 7am... (IMG:style_emoticons/default/smile.gif) I have never used spacers behind the CV's on either end of the axles. What am I missing here? |
tat2dphreak |
Feb 22 2010, 03:35 PM
there's the little quarter-moon shaped spacers 2 per CV, that space 2 bolts each.... if you don't have them on the tranny side, it's not a huge deal because the tranny flanges do not allow the bolt to go all the way through...
if you don't use them on the spindle end of the axle, the bolts go through the spindle and rub the trailing arm. |
EdwardBlume |
Feb 22 2010, 05:27 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
PM Ed... see if you can find someone that may have inspected that area...
and THANKS AGAIN! |
tat2dphreak |
Feb 22 2010, 05:30 PM
clay mentioned that Mike might be going back over there soon, so I PM'd Mike instead.
rick 918-S |
Feb 22 2010, 08:12 PM
Is this like snipe hunting? (IMG:style_emoticons/default/idea.gif) I feel like the guy holding the sack. (IMG:style_emoticons/default/confused24.gif) Got a photo? I've never seen one.
OH! never mind.... I know what your talking about. duh! |
tat2dphreak |
Feb 22 2010, 09:53 PM
I left them out on my car and when I tightened the spindle properly they rubbed, so lesson learned (IMG:style_emoticons/default/smile.gif)
ejm |
Feb 24 2010, 05:39 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,690 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE if they are left off, the bolt will rub the trailing arm and eventually lock up. not something I would be too worried about ....if the bolt should make contact it will either lock right away or quickly clearance itself by rubbing There are several things that need to be looked over... I'm putting a list together |
tat2dphreak |
Feb 24 2010, 09:25 AM
QUOTE There are several things that need to be looked over... I'm putting a list together awesome, Ed! thanks. |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:07 AM |
