CV spacers, did anyone check them on the outside? |
tat2dphreak |
Feb 22 2010, 12:00 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
on the rear outer CVs(were mounted before we started) I just thought of something(well, at 7am I thought of it, but I just got out of bed)... they need to check and make sure the outer ones have the bolt spacers... Dr. Evil put the 4 spacers on the transmission CVs, but we didn't check the outside ones, since they were already mounted.
if they are left off, the bolt will rub the trailing arm and eventually lock up. this woke me up at 7am... (IMG:style_emoticons/default/smile.gif) |
tat2dphreak |
Feb 22 2010, 03:35 PM
there's the little quarter-moon shaped spacers 2 per CV, that space 2 bolts each.... if you don't have them on the tranny side, it's not a huge deal because the tranny flanges do not allow the bolt to go all the way through...
if you don't use them on the spindle end of the axle, the bolts go through the spindle and rub the trailing arm. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:59 PM |
