CV spacers, did anyone check them on the outside? |
tat2dphreak |
Feb 22 2010, 12:00 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
on the rear outer CVs(were mounted before we started) I just thought of something(well, at 7am I thought of it, but I just got out of bed)... they need to check and make sure the outer ones have the bolt spacers... Dr. Evil put the 4 spacers on the transmission CVs, but we didn't check the outside ones, since they were already mounted.
if they are left off, the bolt will rub the trailing arm and eventually lock up. this woke me up at 7am... (IMG:style_emoticons/default/smile.gif) |
ejm |
Feb 24 2010, 05:39 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE if they are left off, the bolt will rub the trailing arm and eventually lock up. not something I would be too worried about ....if the bolt should make contact it will either lock right away or quickly clearance itself by rubbing There are several things that need to be looked over... I'm putting a list together |
Lo-Fi Version | Time is now: 17th May 2024 - 05:12 PM |
