New metric bolts and such, and, what is this black goo? |
EdwardBlume |
Feb 22 2010, 02:47 PM
Where can I find NEW metric bolts and such for my body re-assembly?
and What is the sticky gooey stuff between the body and the horn mount bolt / holder? Can I use left over window goo? Is it really necessary? |
Feb 22 2010, 02:49 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Where can I find NEW metric bolts and such for my body re-assembly? In the "Metric" isle at your hardware store ... (IMG:style_emoticons/default/shades.gif) Andy |
whatabout1 |
Feb 22 2010, 03:06 PM
Toys in Red Group: Members Posts: 403 Joined: 6-March 06 From: Charlotte, NC Member No.: 5,676 Region Association: None |
Avoid the hardware and home improvement stores. You never know what you are getting !!
It's OK for a picnic table not a car, boat or plane. These guys are great http://www.boltdepot.com/DefaultB.aspx |
jonferns |
Feb 22 2010, 03:20 PM
I went to my local Sears hardware store and they have an aisle of bolts of all grades and also metric. I picked up some M8x40mm stainless steel bolts for mounting my bumpers, along with some stainless washers.
tradisrad |
Feb 22 2010, 03:24 PM
You can check Global Metric in San Carlos (maybe Belmont). They seem to close early, but they have a great selection. Call first.
My horns had rubber pads under them. |
detoxcowboy |
Feb 22 2010, 03:41 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Avoid the hardware and home improvement stores. You never know what you are getting !! It's OK for a picnic table not a car, boat or plane. These guys are great http://www.boltdepot.com/DefaultB.aspx You can find 80% of what you need at a hardware store if they carry auto motive grade, which ace hardware does.. you want to look at hardnesses 8.8 10.8 12.9 14.8 ect.. you can get stainless at Ace too.. There are going to be the areas few of them where you need as factory a specific thread pitch and length which can be hard to find anywhere even online.. I have had a problem with 7mm nuts and 14mm nuts of certtain pitch whihc seems to get skipped where the other are available.. there are some specialty wahser you may never find.. But 80% of the items commonly needed are there |
Eric_Shea |
Feb 22 2010, 03:45 PM
Use the following together:
http://www.mcmaster.com and http://www.porsche.com/international/acces...partscatalogue/ The goo? Yes, use the butyl tape from a rear window install. |
detoxcowboy |
Feb 22 2010, 03:46 PM
You will eventually find that black tar everywhere, factory assembly.. I found some places it helped and others it did not matter, I have not found any that was particularly critical.. (IMG:style_emoticons/default/confused24.gif) under roll bar trim, firewall cabeling, tailight, foward floor corner, ect. ect. ect. behing seatbelt mounts.. seamed to be around small openings.. |
underthetire |
Feb 22 2010, 03:55 PM
And really, Orchard Supply Hardware has a ton of metric stuff. I buy all my flange bolts there for the old dirtbikes. Ace by my house has a whole section of automotive fasteners from the plastic trim plugs to exhaust studs.
VaccaRabite |
Feb 22 2010, 04:55 PM
En Garde! Group: Admin Posts: 13,451 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The ACE around me SUCKS. But the 2 TrueValue stores have a good selection of Metric stuff.
Zach |
EdwardBlume |
Feb 22 2010, 11:44 PM
Thanks guys... I found lots of metric bling at the ACE up the street from work.... got the front air dam installed....
Nice work sww914... Attached thumbnail(s) |
EdwardBlume |
Feb 22 2010, 11:46 PM
... and I used the rear window butyl around the horn mounts......
Are the horns multi functional.. ie current in or out either way? Also, CW question: is which sides are the correct sides for #3 and #4 horns??? |
BigD9146gt |
Feb 23 2010, 09:48 AM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
Thanks guys... I found lots of metric bling at the ACE up the street from work.... got the front air dam installed.... Nice work sww914... Nice, the Ace's really do have a great selection (at least in this area). But if you ever need more specialized sizes, Metric Man in San Jose (on 10th? around 101 and 880) can get you all the odd ball stuff. I second that, Steve does great work! |
d914 |
Feb 23 2010, 02:20 PM
dumb question???? Do we have a list of most used hardware???? If buying a bunch new it would be nice to Know....
EdwardBlume |
Feb 24 2010, 04:02 PM
Is there a parts washer solution that can restore oxidized and lightly rusted bolts and fastners?
McMark |
Feb 24 2010, 06:51 PM
Rob, there's a place in Sac that'll replate for cheap. Just throw everything in a box with your name address phone and what you want and they fix it up and send it back.
And don't waste your time cleaning lightly rusty/oxidized parts. They'll look exactly the same in no time unless they're replated. Cleaning them is satisfying, but ineffective. Attached image(s) |
914Sixer |
Feb 24 2010, 07:20 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
That gooey stuff behind the horn mount bolt is really a rubber washer. Use the ones from the plumbing section because they are fiber reinforced.
Dr Evil |
Feb 24 2010, 07:55 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I use BoltDepot.com
sww914 |
Feb 24 2010, 09:01 PM
Thanks for the compliments, guys. It was a pleasure to finish Rob's car. He is the most appreciative customer ever and I hope the car brings him nothing but joy.
Sounds like a fucking anniversary card but it's true. I am impressed with the quality of fasteners at Fastenal, FWIW. |
EdwardBlume |
Feb 24 2010, 10:33 PM
Rob, there's a place in Sac that'll replate for cheap. Just throw everything in a box with your name address phone and what you want and they fix it up and send it back. And don't waste your time cleaning lightly rusty/oxidized parts. They'll look exactly the same in no time unless they're replated. Cleaning them is satisfying, but ineffective. Thanks for the reference... can you recall the name or street address? |
Lo-Fi Version | Time is now: 29th May 2024 - 07:03 AM |
