OK. Laugh if you want, ..for us unmechanical types |
bandjoey |
Feb 26 2010, 05:46 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I don't know how deep the oil is inside the pan, above the push rods. Do I drain the oil before changing push rod tube seals or unnecessary? Logic says yes, but the experts say - - -
(IMG:style_emoticons/default/pinch.gif) |
dr914@autoatlanta.com |
Feb 26 2010, 05:55 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I don't know how deep the oil is inside the pan, above the push rods. Do I drain the oil before changing push rod tube seals or unnecessary? Logic says yes, but the experts say - - - (IMG:style_emoticons/default/pinch.gif) NO |
bandjoey |
Feb 26 2010, 06:04 PM
With a resounding NO, that's good enough for me! (IMG:style_emoticons/default/biggrin.gif) Thanks
KaptKaos |
Feb 26 2010, 07:27 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Is the engine out of the car? On an engine stand perhaps?
bandjoey |
Feb 26 2010, 07:33 PM
Tall jackstands. I've pulled off all the heater parts except the heat exchangers, and it looks ok to do in the car.
Q? I plan to blow out each tube hole with compressed air before pulling it out, and then clean the area with a lint free rag before reinstalling the tube. Viton seals...just use motor oil on the new seal when installing? |
McMark |
Feb 26 2010, 07:34 PM
Nope. (IMG:style_emoticons/default/cool.gif)
Feb 26 2010, 08:44 PM
Just oil on the seals, yes. Clean up the bores in the heads and the case, yes. Make sure there are no ridges to cut the seals.
--DD |
sww914 |
Feb 26 2010, 08:56 PM
I'd recommend a bit of brakleen or carb cleaner on the outside (engine outside, the grimy part) of either end of the tubes before you pull them out, too.
Feb 26 2010, 09:43 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'd recommend a bit of brakleen or carb cleaner on the outside (engine outside, the grimy part) of either end of the tubes before you pull them out, too. (IMG:style_emoticons/default/agree.gif) And don't use chopsticks! (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 18th May 2024 - 12:50 PM |
