bandjoey
Feb 26 2010, 05:46 PM
I don't know how deep the oil is inside the pan, above the push rods. Do I drain the oil before changing push rod tube seals or unnecessary? Logic says yes, but the experts say - - -
dr914@autoatlanta.com
Feb 26 2010, 05:55 PM
QUOTE(bandjoey @ Feb 26 2010, 04:46 PM)
NO
bandjoey
Feb 26 2010, 06:04 PM
With a resounding NO, that's good enough for me!
Thanks
KaptKaos
Feb 26 2010, 07:27 PM
Is the engine out of the car? On an engine stand perhaps?
bandjoey
Feb 26 2010, 07:33 PM
Tall jackstands. I've pulled off all the heater parts except the heat exchangers, and it looks ok to do in the car.
Q? I plan to blow out each tube hole with compressed air before pulling it out, and then clean the area with a lint free rag before reinstalling the tube. Viton seals...just use motor oil on the new seal when installing?
McMark
Feb 26 2010, 07:34 PM
Nope.
Dave_Darling
Feb 26 2010, 08:44 PM
Just oil on the seals, yes. Clean up the bores in the heads and the case, yes. Make sure there are no ridges to cut the seals.
--DD
sww914
Feb 26 2010, 08:56 PM
I'd recommend a bit of brakleen or carb cleaner on the outside (engine outside, the grimy part) of either end of the tubes before you pull them out, too.
Feb 26 2010, 09:43 PM
QUOTE(sww914 @ Feb 26 2010, 06:56 PM)
And don't use chopsticks!
Andy
