V8 tranny questions |
Brett W |
Mar 27 2004, 08:55 AM
What is involved in running a 915 behind a V8. I know you either have to flip the ring and pinion or run the tranny up side down. Is that possible? What are the good options for shifting one?
What are decent used ones going for? How much will I have to throw at one to freshen it up? What gear ratios are available stock? What years should I look for? I need something that can handle a LS1 on steroids. |
rick 918-S |
Mar 27 2004, 09:37 AM
Hey nice rack! -Celette Group: Members Posts: 20,449 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Great Q's... I may need to look at that option next year myself.
boxstr |
Mar 27 2004, 10:42 AM
Brett from what B told me is that the 915 can be used and is probably the best choice, short of a 930 Turbo 4 spd and or a Pantera gearbox.
I would suggest contacting Brad with a PM and asking him some of the questions you have posed here. Or you might find more answers in the Archives?? I personally will use the 915 gear box with the Wevo rear cover setup, $$$$ yes I am already prepared for that but I feel the V8 914 conversion weak link is the trans , so lets just get that out of the way and have fun. CCLIN915V8914 |
jridder |
Mar 27 2004, 06:26 PM
Member Group: Members Posts: 136 Joined: 5-May 03 From: Sunnyvale, CA Member No.: 656 |
Most people don't recommend the 915 with V8's. The torque capacity vs. a 901/914 isn't that much better. If you are making big power, you should just skip the 915 and go for a 930. The cost is probably about the same. There are a couple of 914 V8's in the Bay Area with Pantera transaxles. A nice choice but hard to find.
Mar 27 2004, 07:06 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Brett W @ Mar 27 2004, 06:55 AM) What is involved in running a 915 behind a V8. I know you either have to flip the ring and pinion or run the tranny up side down. Is that possible? What are the good options for shifting one? yupp, 915 is the easiest. just flip the ring & pinion ... 930 is a bit more work. it's either upside/down or machine/casework. Andy PS: what's really weird with those, if you don't have a limited slip, it'll spin the right (pass) tire instead of the left (driver side). feels "wrong" for the first few days. (IMG:style_emoticons/default/cool.gif) (cause i'm used to braking loose on left turns, not right turns) ... |
neo914-6 |
Mar 27 2004, 07:07 PM
Brad is a good source for information as is Renegade Hybrids, and Kennedy Engineering. Decide what you kind of car you want and do your research. Match the transmission, CV/axles, traction, and braking power to the engine power.
LS6/914 |
Mar 27 2004, 07:58 PM
Never leaves the shop member Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest |
If you are heading the LS1 route and can make it fit source a 930 tranny. A 915 will work however when you pass 500hp/400lb.ft torque the advantage of the stronger 930 is the better option. Iam just finishing a Lingenfelter head 302 w/ a 915 for a customer. It will use a cable shift. Iam certain that come fall I will be sourcing a 930 for a upgrade.
Rgreen914 |
Mar 27 2004, 08:38 PM
Member Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 |
LS6/914
Your club moniker always intrigues me and I picture a teener with a big block sticking out of the engine bay, forgetting that Chevy has resurrected some important names/numbers from out of their past! How old are your LPE heads? Just wondering if things have changed much for the company since John died last year; I'm also wondering if they will continue to live up to his high standards. |
914gem |
Mar 27 2004, 11:37 PM
Member Group: Members Posts: 91 Joined: 5-January 03 From: Greenwood Arkansas Member No.: 89 |
Richard Fisher from Plano Tx has been running a 915 behind a high horse SB for a few years. You can find him through Rich Johnson at a914guy@aol.com. They can fill you in on all your answers and cost.
Brad Roberts |
Mar 28 2004, 12:45 AM
I sold Richard his 915 several years back. He has broken it at least twice behind his 450hp SBC. He used the Vellios kit and the RHS tall R+P.
1st gear in the 915 hangs off the end just like a 901/914 box. The ratios are kinda weird for a V8. First is too short and second is almost too tall. When time/money permits I will have WEVO fired up again to cast us a new end cover for the 930 box like they did for the 915. I also spoke on Friday to a fellow who can make us new R+P's for G50 boxes (so we can run them mid-engine without flipping them.) I think the 915 works fine behind a 400-450hp SBC. You just cant beat on 1st gear. Ratios are readily available.. WEVO has THE mid-engine shifting solution for it... RHS has TALL R+P sets for sale. Making the 930 box work is a royal pain in the ass until we have a mid-engine shift solution. B |
Brett W |
Mar 28 2004, 10:13 AM
One of my problems with the Turbo tranny is it is a Four speed. I want to be able to get in and drive to california and have a solid over drive. I was talking to a friend of mine that is putting Ls1-Ls6 engines in 2nd and third gen RX7s and he gets to use the nice T56 6speed tranny. He says he can pull 28-30mpg on the high way. That is the reason I want to use the 915.
I have a friend that is building a 352 from a 400 block and 302 crank figuring about 600hp, but very little torque. something like that should work well with the 915. What is the story on the G50? Brad what does the WEVO kit go for? |
jridder |
Mar 28 2004, 12:08 PM
"Over drive" is meaningless. 3rd and 4th gear on a 930 ARE "overdrive". So what. What matters is the total drive ratio in each gear. A stock 930 has a lower high gear (4th) than a 915 (5th).
Brad Roberts |
Mar 28 2004, 12:13 PM
WEVO shift pieces for the 915 run 1800$.
Ridder is correct (Brett knows this, but probably didnt know the 930 final ratios) Brett, a 930 box turns about 2400 RPM at 75 with a 23/24 inch tall tire (not doing the math..just recalling what I normally see) With the torque of a SBC you can run around town in 2nd gear all day and make 140mph blasts in 4th. B |
seanery |
Mar 28 2004, 12:17 PM
you guys are making me crazy with all this V8 talk. I've gotta build a hotrod before I start tearing up a perfectly good 914! (IMG:style_emoticons/default/wacko.gif)
Brad Roberts |
Mar 28 2004, 12:50 PM
I have been making 125mph blasts up and down 101 while tuning the injection on the green car I posted about. The Woodside to 101 ramp is semi long with a S turn leading onto the straight portion of the ramp. The car will be at 130mph before the end of the ramp if I exit the S correctly. I was actually testing the new Tarret sway bar through the S when this happened.
Lyressa's car will get a LS1 engine when we recover from my F-up. B |
Chris914n6 |
Mar 28 2004, 08:52 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
QUOTE(Brad Roberts @ Mar 27 2004, 10:45 PM) I also spoke on Friday to a fellow who can make us new R+P's for G50 boxes (so we can run them mid-engine without flipping them.) Making the 930 box work is a royal pain in the ass until we have a mid-engine shift solution. B Please tell me the G50 pieces are going to be not expensive... (IMG:style_emoticons/default/ohmy.gif) Oh yah, I still owe you drawings. My notes were written in Chrisese (IMG:style_emoticons/default/laugh.gif) Chris |
chunger |
Mar 29 2004, 05:51 AM
Member Group: Members Posts: 409 Joined: 11-January 03 From: Albany, CA Member No.: 133 |
What's the best current solution to the 930 shifter problem? Been out of the loop for a while. . . come back and people have G50's reversed, new big brakes for 4 lug hubs, and people stuffing alien 928 motors in. Didn't get a chance to play with Renegade's cable shifter at the fun run, but the helper spring--assisted clutch felt slick on the orange car. .. i.e. wife could push the pedal unlike Hatfield's silver car. Figure hydralic could accomplish the same mechanical advantage with the right lever lengths/cylinder sizes.
At the rate my project is going though I could probably wait for the Wevo castings. . . . just like I could have waited for the 74's to be smog exempt. -'Chung |
JWest |
Mar 29 2004, 07:10 AM
QUOTE(Brad Roberts @ Mar 28 2004, 12:45 AM) 1st gear in the 915 hangs off the end just like a 901/914 box. 5th hangs off the end in the 915. 1st is closest to the final drive. |
Lo-Fi Version | Time is now: 10th May 2024 - 08:05 AM |
