Calling Dr. Evil... How di I get this pin out? |
Mike Bellis |
Mar 4 2010, 08:57 PM
Jeffs9146 |
Mar 4 2010, 09:07 PM
With a punch!
We did it at the clinic on mine! |
bigkensteele |
Mar 4 2010, 09:49 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
It is your standard roll pin. Just clamp it down in a vice and use a drift or punch to drive it out. The hardest part is finding the most appropriate way to get it in the vice, as the assembly is somewhat awkward.
Dr Evil |
Mar 4 2010, 10:10 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yup, what they said (IMG:style_emoticons/default/smile.gif)
bigkensteele |
Mar 4 2010, 10:29 PM
I am but one of the Doc's grasshoppas.... |
EdwardBlume |
Mar 5 2010, 08:26 AM
As a witness to said clinic, put some arm into punching it out...
Katmanken |
Mar 5 2010, 10:40 AM
Looking at the rust and pits on the arm and shaft, I'd start with a lot of PB blaster or other penetrant. Removing the shaft from the arm will be the next bit of fun if the shaft is corroded. The parts are machined to have a tight (no slop) fit and the diameter increase from the rust might prevent/ inhibit removal. Save the roll pin, it's a not easy to find that size and has extra coils for strength
Just don't do like my DAPO and use a drywall screw as a roll pin replacement (IMG:style_emoticons/default/blink.gif) |
Crazyhippy |
Mar 5 2010, 05:01 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Anyone have an extra arm like that floating around? i could use one (IMG:style_emoticons/default/piratenanner.gif)
Dr Evil |
Mar 5 2010, 05:06 PM
I may have one. PM me to remind me and I will look.
Lo-Fi Version | Time is now: 25th May 2024 - 03:35 PM |
