914 1.7 fuel injection help!?, why no fuel from injectors |
pt_700 |
Mar 4 2010, 11:35 PM
Senior Member Group: Members Posts: 1,092 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
my 1.7 quit on me a few weeks ago. i have spark (seems a bit weak) and some fuel pressure in the lines. i understand fuel pressure should be around 29-30 but, i only get about 20 @ the port and the regulator's already all the way up. i removed an injector and cranked the engine but, no fuel came out. any ideas?
benalishhero |
Mar 5 2010, 06:16 AM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Trigger points?
Bleyseng |
Mar 5 2010, 10:00 AM
New fuel filter? fuel lines pinched? Old worn out fuel pump?
Frost |
Mar 5 2010, 12:42 PM
Frost Group: Members Posts: 75 Joined: 9-May 08 From: Houston,TX Member No.: 9,035 Region Association: Southwest Region |
Im having a no start/fuel problem with my 914 too, i wonder how yours is going to play out and if it might be the same problem as mines.
JeffBowlsby |
Mar 5 2010, 02:13 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
pbanders |
Mar 5 2010, 07:06 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I'm guessing a dead fuel pump. Follow instructions on the Pelican Parts web site to check the fuel pumping volume. Look for an article in the 914 section by Kjell N.
pt_700 |
Mar 6 2010, 03:19 PM
thanks for all the tips! i poured a little fuel into the intake after removing the air cleaner and it fired right up momentarily so, i'm sure it's a lack of fuel keeping her from starting. although there's very little mention of it in my 3 crummy shop manuals, i'm suspecting the trigger points in the distributor. am i correct in guessing these trigger the fuel injectors? i have about 20 lbs of pressure in the fuel lines.
904svo |
Mar 6 2010, 04:48 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
don't forget to check the ground wires on the back of the engine..
pbanders |
Mar 7 2010, 09:13 AM
thanks for all the tips! i poured a little fuel into the intake after removing the air cleaner and it fired right up momentarily so, i'm sure it's a lack of fuel keeping her from starting. although there's very little mention of it in my 3 crummy shop manuals, i'm suspecting the trigger points in the distributor. am i correct in guessing these trigger the fuel injectors? i have about 20 lbs of pressure in the fuel lines. While it could be the trigger contact points, with only 20 psig of fuel pressure and the regulator wide-open, I suspect your fuel pump. A good fuel pump is capable of over 60 psig of pressure and has to be regulated down to 30 psig. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:15 PM |
