| KaptKaos |
Mar 5 2010, 12:35 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
A few months ago I screwed up my head by drilling in a step down stud crooked, thereby causing the exhaust not to seal.
So I dropped the motor and pulled the head last weekend. One of the cylinder is stuck to the head. As I pulled the head up, the rings on the piston broke. Additionally, some of the cooling fins on the cylinder broke too. When I got the motor, I was told it was a 1911. So in theory, I have 96mm pistons. I hope to measure things this weekend. Here are my questions: 1) Assuming they're 96mm pistons, can I get new rings for them? If so, where? 2) Can I have a spare cylinder bored to replace the cylinder where I broke the fins? If those are both yes, what should I expect when I put it all back together? Should I re-ring all of the cylinders while I am in there? Thanks in advance for your help. |
| detoxcowboy |
Mar 5 2010, 01:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
96M-2145 Piston Ring Set, Oversize, 96mm (1.5/1.75/4.0), 914 2.0 (1973-76), complete set of 4 [More Info]
$60.00 pelican parts, also googled 96mm rings and they are everywhere |
| detoxcowboy |
Mar 5 2010, 01:20 PM
VW Porsche 96mm Big Bore 2.0L Piston Cylinder 914 Bus
96MM Big Bore Kit for 2.0 Type 4, Bus and Porsche 914 Location: California (30 mi from 92866, USA) Store: kokopartsSeller User ID: kokopartsFeedback: 1,246 | 99.7%Watch this item Buy It Now or Best Offer $259.00 +$24.73 shipping ebay for an entire kit of 4. by the time you bore and get right sized rings , ect if you can find 1 cylinder.. you would be at least half way to a new set of 4 |
Lo-Fi Version | Time is now: 12th December 2025 - 09:00 AM |
