Old Fart Attempts Rebirth of Garage Queen Gone Bad!, This is the year! |
Pat Garvey |
Mar 8 2010, 08:24 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
I meant to do this last year, but a lot of health & family things kept it from happening. Those are past history. So, now the process begins of bringing "Fritz" back to life.
For those uniformed, Fritz is my first Porsche. He could still win any concours, except he won't start! Each time I bought another Porsche, Fritz suffered. Nunca mas! My former 20 year love Bluto is in good hands, and I have no more excuses. I place this text here for help and experience from those who've done this before. Number one problem is the fuel system. My tank is so purty from the outside, but gross on the inside - been sitting for 4 years with rotten gas in it. I bought a "new" tank over the winter, but the PO rattle canned it & it looks like poop. It's a primo tank, just looks like crap. Now, as soon as my garage temp hits 55 (I have old hands & they don't like cold temps), I'll drain the old tank & see if it's salvagable. If not, I'll have the "new" tank stripped & resprayed. This will be the first step. So, I have some questions: 1. The car hasn't been started, or attempted. Should I have concerns about the pump? After all, it has old gas in it too. 2. Injectors - should I just change them (since they probably have old gas in them too). I have some new ones ready to go. 3. Anything else I should check in the fuel system, assuming I have a new/restored tank? I probably should have posted this in the Garage, but I wanted opinions from other wienies first. Fritz WILL hit the road this summer. Yes, I will get some help from professionals to make it happen. Yes, I will spend some bucks. But.. first, I have to do something on my own - the tank. Opinions and tech help appreciated. Pat |
ghuff |
Mar 8 2010, 08:26 PM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
Have your injectors cleaned by witchunter injection.
That will fix them well. Use a jiggle hose to drain your tank. I just did that with mine, took a bit but it's almost ready to come out. |
Pat Garvey |
Mar 9 2010, 07:55 PM
ghuff |
Mar 9 2010, 08:11 PM
Have your injectors cleaned by witchunter injection. That will fix them well. Use a jiggle hose to drain your tank. I just did that with mine, took a bit but it's almost ready to come out. Ummm, what's a "jiggle hose"? Pat The name implies, it is a hose you ijggle and the action pulls the fluid up. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.beetletools.com-10389-1268187083.1.jpg) There is a little ball in the end that causes suction and it will drain your tank fairly quick. I pulled 10 gallons from my 914 in about 25 minutes. Only thing better is an electric fuel pump with a switch. |
Pat Garvey |
Mar 10 2010, 07:10 PM
Have your injectors cleaned by witchunter injection. That will fix them well. Use a jiggle hose to drain your tank. I just did that with mine, took a bit but it's almost ready to come out. Ummm, what's a "jiggle hose"? Pat The name implies, it is a hose you ijggle and the action pulls the fluid up. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.beetletools.com-10389-1268187083.1.jpg) There is a little ball in the end that causes suction and it will drain your tank fairly quick. I pulled 10 gallons from my 914 in about 25 minutes. Only thing better is an electric fuel pump with a switch. Where do I get one? Need it quickly! I'm rolling & you don't want to let an OF rest! Pat |
Lo-Fi Version | Time is now: 20th May 2024 - 10:26 AM |
