| PeeGreen 914 |
Mar 12 2010, 10:20 PM
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest
Most of you know of the car and the work that has gone into this car. For those that don't know the car:
1974 914 converted to a 6 by the previous owner. He used all the original 6 components and did a good job in the modification. I have done a good deal of work on the car and turned it into a GTU class winner and then an MU class winner in the PNW region. The cars specs: Engine - 2.4l E, motor specs, 2.4 S spec heads new guides valve job, 2.2 E pistons, E cams, std crank, resized rods, oil bypass mod, Lightened flywheel, Balanced, new rings, bearings, rod bolts, chains,gaskets. Transmission - 901 side shift with a lightened flywheel and TB dif. Gears are stock 1 and 2 with an M 3rd S 4th and a stock 5th. Rennshift Suspension - Elephant racing polybronze bushings all new last year. Tarret 23mm antisway bar. 23mm hollow torsion bars. 911 front and aluminium cross-member. 250lb rear springs. Weltmeister camber plates. 944CVs with early 911 input and output flanges. H&R Spacers, about 1" (easy to remove for autocrossing). Brakes - S calipers in front and M calipers in the rear with a 911 ebrake system almost set up. 21mm master cylinder with a JWest proportion valve in the cab. Other - Rennshifter with a killer wood knob made by Zach. Solid shift pushings by Patrick motorsport. Firewall engine mount by Patrick. the car has many other modifications. It is perfectly set up and ready for the next owner to enjoy. Attached image(s)
| carr914 |
Mar 13 2010, 12:16 AM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 135,800 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
WHAT? (IMG:style_emoticons/default/yikes.gif)
Who are we going to Vote into 2nd Place for the COTM now? T.C. |
| U N S E E N |
Mar 13 2010, 04:07 AM
Newbie ![]() Group: Members Posts: 6 Joined: 16-November 09 From: El Paso TX Member No.: 11,048 Region Association: Southwest Region |
I cant believe youre selling this car! Literally my dream 914!!! Wow. GLWS (IMG:style_emoticons/default/beerchug.gif)
| bcheney |
Mar 13 2010, 08:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Are those factory steel flares?
| PeeGreen 914 |
Mar 13 2010, 06:56 PM
Sorry I didn't reply right away. I just got home from and autocross (IMG:style_emoticons/default/smile.gif)
The flares are glass. Well done but as all glass it doesn't fair as well as steal. The TB dif is a Gaurd Torque Biasing dif. Attached image(s)
| PeeGreen 914 |
Mar 13 2010, 07:02 PM
more (IMG:style_emoticons/default/drunk.gif)
| Dirty Evo |
Mar 14 2010, 11:04 AM
Member ![]() ![]() Group: Members Posts: 79 Joined: 2-January 10 From: NorCal Member No.: 11,198 Region Association: Northern California |
gorgeous.... I want this car!
it does NOT have a full roll cage, correct? |
| PeeGreen 914 |
Mar 14 2010, 11:21 AM
No, it has a few areas I reinforced to make it stiff but no cage. Only the Engman inner kit and Tangerine's ear kit. I did have Jeff (Sixnotfour) make me some nice pieces to go where the four mounts use to be as I removed them and welded on these (IMG:style_emoticons/default/smile.gif)
| porschecb |
Mar 14 2010, 01:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
Why are you selling your car?
| PeeGreen 914 |
Mar 14 2010, 01:20 PM
Well, I sell real estate and have, as most agents have, had a rough year. I now have another job until the market picks back up but I just want to get rid of this massive debt. I literally got this car to a place where there is very little to do to it and, those that know me know, I need projects. So I get to kill two birds with one stone. I get to wipe most of my debt out and start another project. May need to wait a while for the new project but I am okay with that.
Not only that, I have a son that is turning 4 this summer. He has been able to watch me do some things on this car but not really get his hands dirty. With a new project he will get to work with me (IMG:style_emoticons/default/smile.gif) If I could keep this car I would. If the day comes when I can buy it back...and the new owner wants to sell... I certainly will. |
| jcambo7 |
Mar 15 2010, 06:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,703 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
Man Jon. I wish I could buy your car...I have always loved it...I would probably end up giving it back to you though. (IMG:style_emoticons/default/drunk.gif)
| PlaysWithCars |
Mar 15 2010, 09:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 545 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest
Sounds like a great deal John. Sell it to James and he'll give it back to you. (IMG:style_emoticons/default/piratenanner.gif) (did I read that right? (IMG:style_emoticons/default/blink.gif) )
The car looked, sounded, and ran great at the autocross on Saturday John. It will be a fun ride for someone. Good luck with the sale. |
| pete-stevers |
Mar 15 2010, 09:13 PM
Shinee Side Up ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
Very nize!! i wish you well Jon!!!
and bump! |
| Eddie914 |
Mar 18 2010, 09:32 AM
Unregistered |
Jon,
Fabulous! Clean, Clean Clean! All the best upgrades. Good luck with the sale. I hope your next project is another 914. Eddie |
| Quilmes |
Mar 18 2010, 07:30 PM
Torino 380 W ![]() ![]() Group: Members Posts: 358 Joined: 26-January 05 From: Orlando, FL Member No.: 3,510 |
Nice car, please call me. 407-259-1259.
| PeeGreen 914 |
Mar 18 2010, 10:51 PM
Sorry I didn't get this until now. I will give you a call tomorrow morning.
| PeeGreen 914 |
Mar 20 2010, 08:09 PM
Anyone want to see some of the purty parts on this car?
944 CVs (IMG:style_emoticons/default/aktion035.gif) Attached image(s)
| PeeGreen 914 |
Mar 24 2010, 12:21 PM
| Dirty Evo |
Mar 24 2010, 10:46 PM
damn it, every time I look at this thread , I want the car... but just not feasible at the moment.
you would think at almost 40 years old , I could be a mature adult about things... but no, what I want to do is throw myself onto the floor and kick and cry until my wife says "ok"... i see my 11 month old boy does it, and it works for him!! i can just picture myself driving this think around thunderhill! |
| PeeGreen 914 |
Mar 25 2010, 09:37 AM
If you do end up being able to buy it I hope you'll let me come take it around Thunder Hill. I have always wanted to drive that track (IMG:style_emoticons/default/piratenanner.gif)
Lo-Fi Version | Time is now: 11th November 2026 - 09:06 PM |
