SOLD: 1974 914-6 GT Clone, $17,500.00 |
PeeGreen 914 |
Mar 12 2010, 10:20 PM
Most of you know of the car and the work that has gone into this car. For those that don't know the car:
1974 914 converted to a 6 by the previous owner. He used all the original 6 components and did a good job in the modification. I have done a good deal of work on the car and turned it into a GTU class winner and then an MU class winner in the PNW region. The cars specs: Engine - 2.4l E, motor specs, 2.4 S spec heads new guides valve job, 2.2 E pistons, E cams, std crank, resized rods, oil bypass mod, Lightened flywheel, Balanced, new rings, bearings, rod bolts, chains,gaskets. Transmission - 901 side shift with a lightened flywheel and TB dif. Gears are stock 1 and 2 with an M 3rd S 4th and a stock 5th. Rennshift Suspension - Elephant racing polybronze bushings all new last year. Tarret 23mm antisway bar. 23mm hollow torsion bars. 911 front and aluminium cross-member. 250lb rear springs. Weltmeister camber plates. 944CVs with early 911 input and output flanges. H&R Spacers, about 1" (easy to remove for autocrossing). Brakes - S calipers in front and M calipers in the rear with a 911 ebrake system almost set up. 21mm master cylinder with a JWest proportion valve in the cab. Other - Rennshifter with a killer wood knob made by Zach. Solid shift pushings by Patrick motorsport. Firewall engine mount by Patrick. the car has many other modifications. It is perfectly set up and ready for the next owner to enjoy. Attached image(s) |
PeeGreen 914 |
Mar 14 2010, 01:20 PM
Well, I sell real estate and have, as most agents have, had a rough year. I now have another job until the market picks back up but I just want to get rid of this massive debt. I literally got this car to a place where there is very little to do to it and, those that know me know, I need projects. So I get to kill two birds with one stone. I get to wipe most of my debt out and start another project. May need to wait a while for the new project but I am okay with that.
Not only that, I have a son that is turning 4 this summer. He has been able to watch me do some things on this car but not really get his hands dirty. With a new project he will get to work with me (IMG:style_emoticons/default/smile.gif) If I could keep this car I would. If the day comes when I can buy it back...and the new owner wants to sell... I certainly will. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:57 PM |
