SOLD: 1974 914-6 GT Clone, $17,500.00 |
PeeGreen 914 |
Mar 12 2010, 10:20 PM
Most of you know of the car and the work that has gone into this car. For those that don't know the car:
1974 914 converted to a 6 by the previous owner. He used all the original 6 components and did a good job in the modification. I have done a good deal of work on the car and turned it into a GTU class winner and then an MU class winner in the PNW region. The cars specs: Engine - 2.4l E, motor specs, 2.4 S spec heads new guides valve job, 2.2 E pistons, E cams, std crank, resized rods, oil bypass mod, Lightened flywheel, Balanced, new rings, bearings, rod bolts, chains,gaskets. Transmission - 901 side shift with a lightened flywheel and TB dif. Gears are stock 1 and 2 with an M 3rd S 4th and a stock 5th. Rennshift Suspension - Elephant racing polybronze bushings all new last year. Tarret 23mm antisway bar. 23mm hollow torsion bars. 911 front and aluminium cross-member. 250lb rear springs. Weltmeister camber plates. 944CVs with early 911 input and output flanges. H&R Spacers, about 1" (easy to remove for autocrossing). Brakes - S calipers in front and M calipers in the rear with a 911 ebrake system almost set up. 21mm master cylinder with a JWest proportion valve in the cab. Other - Rennshifter with a killer wood knob made by Zach. Solid shift pushings by Patrick motorsport. Firewall engine mount by Patrick. the car has many other modifications. It is perfectly set up and ready for the next owner to enjoy. Attached image(s) |
PeeGreen 914 |
Mar 25 2010, 09:37 AM
If you do end up being able to buy it I hope you'll let me come take it around Thunder Hill. I have always wanted to drive that track (IMG:style_emoticons/default/piratenanner.gif)
Justinp71 |
Mar 29 2010, 11:43 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
If you do end up being able to buy it I hope you'll let me come take it around Thunder Hill. I have always wanted to drive that track (IMG:style_emoticons/default/piratenanner.gif) I have a similiar car that I've taken on thunderhill with the lotus club and it was a blast! I was giving some lotus elise's a run for there money...lol. |
Dirty Evo |
Mar 30 2010, 06:39 PM
Member Group: Members Posts: 79 Joined: 2-January 10 From: NorCal Member No.: 11,198 Region Association: Northern California |
If you do end up being able to buy it I hope you'll let me come take it around Thunder Hill. I have always wanted to drive that track (IMG:style_emoticons/default/piratenanner.gif) I have a similiar car that I've taken on thunderhill with the lotus club and it was a blast! I was giving some lotus elise's a run for there money...lol. I see you are in Sacramento.. I am up in Auburn I am really torn on this car. I want to turn my Cayman S into a dedicated track car... but my sentimental car is the 914 (I got a 72 1.7 for high school graduation back in '89)... I would LOVE to have one to track and maybe zip around town now and then! if its still available in a month, you just may see it at T-hill this summer... maybe!! |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:31 AM |
