SOLD: 1974 914-6 GT Clone, $17,500.00 |
PeeGreen 914 |
Mar 12 2010, 10:20 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Most of you know of the car and the work that has gone into this car. For those that don't know the car:
1974 914 converted to a 6 by the previous owner. He used all the original 6 components and did a good job in the modification. I have done a good deal of work on the car and turned it into a GTU class winner and then an MU class winner in the PNW region. The cars specs: Engine - 2.4l E, motor specs, 2.4 S spec heads new guides valve job, 2.2 E pistons, E cams, std crank, resized rods, oil bypass mod, Lightened flywheel, Balanced, new rings, bearings, rod bolts, chains,gaskets. Transmission - 901 side shift with a lightened flywheel and TB dif. Gears are stock 1 and 2 with an M 3rd S 4th and a stock 5th. Rennshift Suspension - Elephant racing polybronze bushings all new last year. Tarret 23mm antisway bar. 23mm hollow torsion bars. 911 front and aluminium cross-member. 250lb rear springs. Weltmeister camber plates. 944CVs with early 911 input and output flanges. H&R Spacers, about 1" (easy to remove for autocrossing). Brakes - S calipers in front and M calipers in the rear with a 911 ebrake system almost set up. 21mm master cylinder with a JWest proportion valve in the cab. Other - Rennshifter with a killer wood knob made by Zach. Solid shift pushings by Patrick motorsport. Firewall engine mount by Patrick. the car has many other modifications. It is perfectly set up and ready for the next owner to enjoy. Attached image(s) |
Dirty Evo |
Mar 24 2010, 10:46 PM
Member Group: Members Posts: 79 Joined: 2-January 10 From: NorCal Member No.: 11,198 Region Association: Northern California |
damn it, every time I look at this thread , I want the car... but just not feasible at the moment.
you would think at almost 40 years old , I could be a mature adult about things... but no, what I want to do is throw myself onto the floor and kick and cry until my wife says "ok"... i see my 11 month old boy does it, and it works for him!! i can just picture myself driving this think around thunderhill! |
hot_shoe914 |
Apr 9 2010, 09:50 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
you would think at almost 40 years old , I could be a mature adult about things... but no, what I want to do is throw myself onto the floor and kick and cry until my wife says "ok"... i see my 11 month old boy does it, and it works for him!! Try telling her you will give up drinking and hookers and see if that works. (IMG:style_emoticons/default/confused24.gif) |
Dirty Evo |
Apr 9 2010, 10:05 PM
you would think at almost 40 years old , I could be a mature adult about things... but no, what I want to do is throw myself onto the floor and kick and cry until my wife says "ok"... i see my 11 month old boy does it, and it works for him!! Try telling her you will give up drinking and hookers and see if that works. (IMG:style_emoticons/default/confused24.gif) gonna give it a shot right now... will let you guys know how it goes. never hurts to keep bumping this thread to the top.. maybe help to get this beauty of a car sold!! |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:56 AM |
