Door Stay, Body Pin mount? |
914werke |
Mar 13 2010, 10:19 PM
"I got blisters on me fingers" Group: Members Posts: 10,083 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
not exactly sure what you call it...but, the pin reciver mounted in the front door jamb that secures the door stay's on either side tend to wear & oval out.
On my passenger side I need to do something to correct (IMG:style_emoticons/default/confused24.gif) Any tips or tricks? Weld it up and re drill it? drill it oversize & bush it with ...what? (IMG:style_emoticons/default/sad.gif) |
davesprinkle |
Mar 13 2010, 10:32 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
not exactly sure what you call it...but, the pin reciver mounted in the front door jamb that secures the door stay's on either side tend to wear & oval out. On my passenger side I need to do something to correct (IMG:style_emoticons/default/confused24.gif) Any tips or tricks? Weld it up and re drill it? drill it oversize & bush it with ...what? (IMG:style_emoticons/default/sad.gif) Rich, I'm pursuing this right now. I'll be drilling out the 6mm hole to 1/4" and running a larger clevis pin. Hope to have the project completed this week. Whether it will be successful or not depends on the amount of wear and how accurately I'll be able to drill the holes. If it works I can post some pics of the process. -dave |
bandjoey |
Mar 13 2010, 10:55 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
There's a metal and plastic roller. Find a used stay and take the metal roller off. You can use a small file and resize the metal to the plastic size and Wallah. Rebuild yours with two metal rollers. Worked great on mine. U can probably get a used one for a few $'s or look for a real expensive rebuilD kit.
Search the tech articles here or pelican. There's a rebuild post on how to online |
bandjoey |
Mar 13 2010, 10:59 PM
O. You're talking about where the stay attaches to the body? I was thinking about the inside of the stay. Well here's a freebe when the roller wallows out.
jk76.914 |
Mar 14 2010, 07:04 AM
Mine made a loud rap when the door was opened, as it was approaching full open, because of slack. I investigated oversize pins or bushings, then I discovered that the wear was actually in the aluminum arm that's part of the stay itself. New arm and new pin, and I have a nice tight fit and no rap.
914werke |
Mar 14 2010, 10:41 AM
Mine made a loud rap when the door was opened, as it was approaching full open, because of slack. I investigated oversize pins or bushings, then I discovered that the wear was actually in the aluminum arm that's part of the stay itself. New arm and new pin, and I have a nice tight fit and no rap. Thats what drew me to address this problem, Same symptom, a very audible *clack* I knew it wasent the alum. stay since I had already rebuilt those with Dave's parts (PLUG!) & had used a new unworn pin. Looking it over it is definitely ovaled. So Dave if you drill it out for a larger pin youd also have to drill out the alum. stay as well? Its pretty tight for a drill ? |
davesprinkle |
Mar 14 2010, 11:39 AM
Mine made a loud rap when the door was opened, as it was approaching full open, because of slack. I investigated oversize pins or bushings, then I discovered that the wear was actually in the aluminum arm that's part of the stay itself. New arm and new pin, and I have a nice tight fit and no rap. Thats what drew me to address this problem, Same symptom, a very audible *clack* I knew it wasent the alum. stay since I had already rebuilt those with Dave's parts (PLUG!) & had used a new unworn pin. Looking it over it is definitely ovaled. So Dave if you drill it out for a larger pin youd also have to drill out the alum. stay as well? Its pretty tight for a drill ? Yes, it will require drilling out the hole in the door stay. That's the easy part. The real challenge will be getting a drill into the doorjamb space to drill out the bracket. I'm going to try one of those hex-drive bits in a flex-cable drill extension. It'll be tricky. I'll let you know how this works out. |
davesprinkle |
Mar 15 2010, 12:34 AM
I was prepared to attempt to drill out the bracket holes, and had sourced a flex-cable extension and a hex-drive 1/4" drill bit. It was going to be tricky.
But before I started drilling, I checked my new Mcmaster 1/4" clevis pin in the bracket holes. It was a very tight fit, but it went through with a little effort. So thankfully, no drilling was required on the door jamb bracket. All I had to do was to drill out the hole in the door stay to fit the new pin. I should say that the new pin was undersized from 1/4" -- 0.244" rather than 0.250". So I used a letter-size drill bit (D) rather than 1/4". Result? Success! No more CLACK-CLACK. Now just a light muffled tick-tick. Nice. Obviously, your success with this may vary based on the amount of wear on your bracket. |
914werke |
Mar 15 2010, 10:24 AM
Dave what was the Mcmaster part # for that pin? I might try Tacoma Screw.
J P Stein |
Mar 15 2010, 10:29 AM
Tough to see in the pic, but I shitcanned the mechanism & made a strap out of nylon(?) safety webbing....light too. (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
davesprinkle |
Mar 15 2010, 08:00 PM
Lo-Fi Version | Time is now: 21st May 2024 - 07:18 PM |
