Gauge Lights, Need to find left right blinker and high beam indicators |
ventedrib |
Mar 14 2010, 04:22 PM
Member Group: Members Posts: 104 Joined: 10-August 08 From: Monroe La. Member No.: 9,406 Region Association: South East States |
Hi all about to get anouther suby conversion on the road but I can't seem to find the left right and high beam indicators that go in the tach. Lots of little Bulbs with single black wire I assume are just back lights and a few with bulbs and two wires.For some reason the blinkers are working but the indicators arent and the high beams dont work but have a relay coming that should fix that.Its a 73 and was a 2.0. Any help would be Great.
jt914-6 |
Mar 14 2010, 05:10 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
On my '74 the turn signal indicator wire is blue with a white stripe....The high beam is white with a blue stripe. The bulb holder is self-grounding and needs to be in the tach to ground. Same with the turn signal indicators. Make sure the bulbs are good....
Lo-Fi Version | Time is now: 17th May 2024 - 08:25 PM |
