ventedrib
Mar 14 2010, 04:22 PM
Hi all about to get anouther suby conversion on the road but I can't seem to find the left right and high beam indicators that go in the tach. Lots of little Bulbs with single black wire I assume are just back lights and a few with bulbs and two wires.For some reason the blinkers are working but the indicators arent and the high beams dont work but have a relay coming that should fix that.Its a 73 and was a 2.0. Any help would be Great.
jt914-6
Mar 14 2010, 05:10 PM
On my '74 the turn signal indicator wire is blue with a white stripe....The high beam is white with a blue stripe. The bulb holder is self-grounding and needs to be in the tach to ground. Same with the turn signal indicators. Make sure the bulbs are good....
