Riviera lug seat shape, ball seat, acorn? |
DanT |
Mar 14 2010, 09:18 PM
wheel lug mating surface shape and where did you get the proper lugs?
Sleepin |
Mar 14 2010, 09:32 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Most are conical. I just bought a set of bolts from Prestige Wheel http://www.prestigewheel.com/Image204211c.asp it may be a little more expensive than other sites, but the measurements and graphs on their site impressed me.
Cap'n Krusty |
Mar 14 2010, 10:16 PM
All ball, no taper ........................ The Cap'n
EdwardBlume |
Mar 14 2010, 10:29 PM
Aren't there different Rivs between Bug and 914... I picked up an odd one years ago...
DanT |
Mar 14 2010, 10:31 PM
pretty sure the ones I picked up are cone seat and bug offset....
4" backspace maybe 4.25 at most....good thing the fenders on the '75 I am doing will be slightly pulled (IMG:style_emoticons/default/smile.gif) |
EdwardBlume |
Mar 14 2010, 10:35 PM
pretty sure the ones I picked up are cone seat and bug offset.... 4" backspace maybe 4.25 at most....good thing the fenders on the '75 I am doing will be slightly pulled (IMG:style_emoticons/default/smile.gif) Yes, exactly... the offset is a little wider.. CWs be damned! Did you find a muffler yet? |
DanT |
Mar 14 2010, 11:43 PM
pretty sure the ones I picked up are cone seat and bug offset.... 4" backspace maybe 4.25 at most....good thing the fenders on the '75 I am doing will be slightly pulled (IMG:style_emoticons/default/smile.gif) Yes, exactly... the offset is a little wider.. CWs be damned! Did you find a muffler yet? check out my retro '75 thread....Mike had a Monza that looks very retro...but I still want to pick up the one you offered....might use it just for AXs since it is only a 10 minute change from street to AX. (IMG:style_emoticons/default/smile.gif) |
Tom_T |
Mar 15 2010, 02:51 PM
wheel lug mating surface shape and where did you get the proper lugs? Dan - IIRC the lugs on the original Rivs like I posted on your built topic post used the same semi-spherical base (1/2 round/ball) as the other 4 lug factory alloys (Fuchs, Mahles, Pedrinis). I don't know if those repop Rivs of yours use conical or semi-spherical base> Look at the shape of the countersink in the Rivs you'll be using. Both types are available in chrome from vendors on TheSamba, but get the ones with the +/- 1/4"-1/2" lag or non-threaded space below the head to avoid chewing up the inside of the lug holes in the wheels. ... that's how folks get oval lug holes in alloy wheels over time! (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:23 PM |
