WTB clean early (pre-vent) upper dash pad |
porbmw |
Mar 16 2010, 12:22 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
boxstr |
Mar 16 2010, 02:08 PM
Do you mean the knee pad with no vents??
Craig at CAMP |
Lennies914 |
Mar 16 2010, 06:27 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I don't believe there is a difference in the upper dash. I put one out of a '70 on my '74. I do still have the lower knee pad if that is needed.
gms |
Mar 16 2010, 07:23 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
boxstr |
The early 70 models have a vent in the middle of the upper dash, but it is built into the metal part of the dash not the pad.
Craig at CAMP |
914ltd |
Mar 17 2010, 08:14 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
The early 70 models have a vent in the middle of the upper dash, but it is built into the metal part of the dash not the pad. Craig at CAMP As Glen stated, the early dash top #914 552 031 10 was used with the wider glove box, if you use 914 552 031 12 you can only partially open the glove box door. You would need to cut away part of the underside of the dash to work properly. Brad M. |
Lo-Fi Version | Time is now: 11th May 2024 - 12:10 AM |
