Fuel pump location, on a 72 |
jeffdon |
Mar 18 2010, 04:57 PM
My 72 never had the FI pump under the tank. Car is now carbed, and I am thinking of mounting my carter pump up front. Wheres the easiest place to find a keyed positive?
Also, fuel lines are original. With the pump in the engine bay, i figured that there was not much pressure on them, as the pump was operating to suck the fuel up the line. IF i put it up front, then there will be pressure on the supply lines. Am I creating a situation where leaks are more likely? |
Lo-Fi Version | Time is now: 17th May 2024 - 09:01 PM |
