Broke out the powdercoater today.., Pics of side view mirror..... |
415PB |
Mar 29 2004, 12:54 AM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Powdercoated an extra side view mirror I had. The color is shadow black. The mirror had a 2" dent running across the backside of it. I used a body hammer and dolly and it came out pretty good.
Attached thumbnail(s) |
2-OH! |
Mar 29 2004, 08:20 AM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
How did you prepare the surface before coating...Did you strip the chrome finish, rough it up, sand blast...Or did the Powdercoat stick without any help...
2-OH! |
Rusty |
Mar 29 2004, 08:26 AM
Damn... that's pretty slick. How did you prep the surface?
That's so much better than some of the painted versions I've seen when people black out the chrome. -Rusty (IMG:style_emoticons/default/smoke.gif) |
415PB |
Mar 29 2004, 09:18 AM
After taking apart the mirror I sanded the backside of it with 400 grit then sanded with 600 grit. I dipped the mirror in thinner for 5 minutes and this cleaned it really well. I then powdercoated and cured the mirror housing.
The arm the mirror attaches too, came out a little to glossy, which tells me that I didn't spend enough time getting the chrome off, but it came out alright. I am going to be doing all the chrome on my teener a Matte black, just waiting for the powder to come in. Thanks |
Rusty |
Mar 29 2004, 09:25 AM
It looks really good.
I've never seen a mirror completely disassembled. How tough was it to R&R the glass? -Rusty (IMG:style_emoticons/default/smoke.gif) |
415PB |
Mar 29 2004, 09:31 AM
Rusty, it was pretty easy. Have to be careful prying out the black seal around the outer edge of the mirror though. I nicked the lower portion of the mirror on mine. After prying the black seal, the mirror comes right out.
Take off the 8mm bolt inside and remove a small spring and washer. This will seperate the housing from the elbow. Now if I could only find a place that sells just the mirror. I will be doing a couple more mirrors over the next few days. I will take pics of the inside of them. |
tat2dphreak |
Mar 29 2004, 09:48 AM
415, I just bought 2 replacement mirors, glass only from a guy here in TX, I'll send you his email... $10 each, shipped.
the mirror looks great!! want to do mine? (IMG:style_emoticons/default/wink.gif) |
415PB |
Mar 29 2004, 10:00 AM
QUOTE(tat2dphreak @ Mar 29 2004, 07:48 AM) 415, I just bought 2 replacement mirors, glass only from a guy here in TX, I'll send you his email... $10 each, shipped. the mirror looks great!! want to do mine? (IMG:style_emoticons/default/wink.gif) You know, I remember seeing a guy from Texas on ebay offering just the glass. Cool, please send me the info and yep you can send me the mirrors and I will powdercoat them for you. Rod |
736conver |
Mar 29 2004, 10:16 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Glass for the mirrors is under $2 at any glass shop. I replaced mine last year. Took the mirror down to local shop and the next day and $3 later I had new mirrors.
415PB |
Mar 29 2004, 10:24 AM
Cool, I will try that also...
Thanks |
Rusty |
Mar 29 2004, 10:30 AM
If you get the replacement glass piece before hand, why not just carefully break the mirror to help save wear and tear on that seal.
Is the seal available anywhere? -Rusty (IMG:style_emoticons/default/smoke.gif) |
tat2dphreak |
Mar 29 2004, 10:34 AM
QUOTE(415PB @ Mar 29 2004, 10:00 AM) QUOTE(tat2dphreak @ Mar 29 2004, 07:48 AM) 415, I just bought 2 replacement mirors, glass only from a guy here in TX, I'll send you his email... $10 each, shipped. the mirror looks great!! want to do mine? (IMG:style_emoticons/default/wink.gif) You know, I remember seeing a guy from Texas on ebay offering just the glass. Cool, please send me the info and yep you can send me the mirrors and I will powdercoat them for you. Rod that's the guy... they fit perfect... but I have issues with 1 mirror, the plastic backpiece was broke/rotted and won't hold the mirror in place, even with the front piece (IMG:style_emoticons/default/confused24.gif) I also have to remove my current mirrors since the PO put the in a weird spot(on the windshield frame) (IMG:style_emoticons/default/stfu.gif) I'll have to fill in those holes... I'm pretty pissed about that! |
415PB |
Mar 29 2004, 10:53 AM
Rusty, the seal is actually pretty tough and pliable. I haven't heard of any place that offers the seal, I have to ckeck into this.
"I was kidding about the powdercoat" So was I (IMG:style_emoticons/default/laugh.gif) As far as the plastic frame behind the mirror, mine was also broken in half. I used foglight seal material behind the mirror and it works just fine. Rusty I will try and locate those black seals and see if they are still available. I'll let you know. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:59 PM |
