distributor removal |
sixers34926 |
Mar 21 2010, 10:02 PM
Member Group: Members Posts: 83 Joined: 11-February 10 From: Phoenix, AZ Member No.: 11,352 Region Association: None |
can someone please explain how to remove the dizzy. maybe even some pictures as i am clueless when it comes to the dizzy. thanks in advance
jimkelly |
Mar 21 2010, 10:09 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
at the base of the dizzy is a plate with a hole on it for the sutd from the block to go thru and for a nut to hold it in place.
above this is a long hex nut that you have to loosen in order to rotate dizzy, so you can get the the nut on the plate. Attached image(s) |
SLITS |
Mar 21 2010, 10:12 PM
Dynamite .... (IMG:style_emoticons/default/biggrin.gif)
sixers34926 |
Mar 21 2010, 10:13 PM
wow thanks jim thats exactly what i needed! (IMG:style_emoticons/default/beerchug.gif)
Cap'n Krusty |
Mar 21 2010, 10:22 PM
Ya might wanna set the engine on TDC #1 before you remove the distributor, as it makes it a LOT easier to get it back in a close-to-correct location so the car will start. The Cap'n
Lo-Fi Version | Time is now: 19th May 2024 - 03:54 PM |
