sixers34926
Mar 21 2010, 10:02 PM
can someone please explain how to remove the dizzy. maybe even some pictures as i am clueless when it comes to the dizzy. thanks in advance
jimkelly
Mar 21 2010, 10:09 PM
at the base of the dizzy is a plate with a hole on it for the sutd from the block to go thru and for a nut to hold it in place.
above this is a long hex nut that you have to loosen in order to rotate dizzy, so you can get the the nut on the plate.
SLITS
Mar 21 2010, 10:12 PM
Dynamite ....
sixers34926
Mar 21 2010, 10:13 PM
wow thanks jim thats exactly what i needed!
Cap'n Krusty
Mar 21 2010, 10:22 PM
Ya might wanna set the engine on TDC #1 before you remove the distributor, as it makes it a LOT easier to get it back in a close-to-correct location so the car will start. The Cap'n
