rocker arm assy's |
rocker arm assy's |
TheCabinetmaker |
Mar 29 2004, 11:19 AM
I scored a 2.0L basket case (case is together) that seems to missing only the rocker arm assemblies. Will those from a 1.7 or 1.8 work? will they have the proper geometry? I know the adjuster lock nuts are 13mm on the 1.7 and 14 mm on the 2.0. any other differences?
thanks in advance, Curt |
machina |
Mar 29 2004, 11:28 AM
pretty sure they will work. actually the 1.7 rockers are preffered because the 911 swivel adjusters will fit.
think all type IV's have same rocker ratio and shaft size. dr |
Mark Henry |
Mar 29 2004, 11:30 AM
Yep, just bolt them on.
1.7 with the 8mm screws are what the hipo guys want, they all work for a stock app. |
TheCabinetmaker |
Mar 29 2004, 12:38 PM
Thanks guy's. This is a stock 2.0. I'll use the 1.8's and save the 1.7's for the "big" project.
Lo-Fi Version | Time is now: 11th May 2024 - 11:26 PM |
