TheCabinetmaker
Mar 29 2004, 11:19 AM
I scored a 2.0L basket case (case is together) that seems to missing only the rocker arm assemblies. Will those from a 1.7 or 1.8 work? will they have the proper geometry? I know the adjuster lock nuts are 13mm on the 1.7 and 14 mm on the 2.0. any other differences?
thanks in advance, Curt
machina
Mar 29 2004, 11:28 AM
pretty sure they will work. actually the 1.7 rockers are preffered because the 911 swivel adjusters will fit.
think all type IV's have same rocker ratio and shaft size.
dr
Mark Henry
Mar 29 2004, 11:30 AM
Yep, just bolt them on.
1.7 with the 8mm screws are what the hipo guys want, they all work for a stock app.
TheCabinetmaker
Mar 29 2004, 12:38 PM
Thanks guy's. This is a stock 2.0. I'll use the 1.8's and save the 1.7's for the "big" project.
