Factory Hole in Floor Pan |
saigon71 |
Mar 22 2010, 06:10 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
iamchappy |
Mar 22 2010, 06:30 PM
I may be wrong but i believe those were access holes the factory used so they could use there spot welders.
Eric_Shea |
Mar 22 2010, 06:37 PM
(I think he's talking about the little one in the corner) (IMG:style_emoticons/default/wink.gif)
rick 918-S |
Mar 22 2010, 06:40 PM
Hey nice rack! -Celette Group: Members Posts: 20,459 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
First, Chappy, I think your right about the removable plugs in the pan. (IMG:style_emoticons/default/agree.gif) But the 8mm hole is still a mystery. (IMG:style_emoticons/default/confused24.gif)
bigkensteele |
Mar 22 2010, 07:12 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Did this car have A/C? Could be for a condensation hose. That would have been done by the dealer, and I would think it would be larger, so I don't know.
dr914@autoatlanta.com |
Mar 22 2010, 07:21 PM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
saigon71 |
Mar 22 2010, 07:39 PM
I am referring to the small hole at the front of the pan (about 1/4" in diameter).
I don't know if the car was ever equipped with A/C...and I have no plans on installing it, so I guess I will just close it off. Thanks for the responses - I appreciate the info. Bob |
iamchappy |
Mar 22 2010, 08:55 PM
I didn't even notice that tiny spot that looks like a hole.
1968Cayman |
Mar 23 2010, 02:34 AM
Redacted by Irving Washington Group: Members Posts: 116 Joined: 5-February 10 From: Holly Springs, GA Member No.: 11,332 Region Association: South East States |
There is supposed to be a rubber plug there; I only know because I wire-wheeled through one of them two days ago that was about 10" to the left of the one you have pictured. The one I destroyed was near the tunnel and only then did I notice the other.
ClayPerrine |
Mar 23 2010, 06:21 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
First, Chappy, I think your right about the removable plugs in the pan. (IMG:style_emoticons/default/agree.gif) But the 8mm hole is still a mystery. (IMG:style_emoticons/default/confused24.gif) Nope... I know what they were for. Saw it in a video. The same holes appear in the 356 and early 911 chassis. The factory used them to fasten the stamped panels to the alignment jig. The panel was placed over a block on the jig that was turned to lock it in place. Then they were all welded together, and the blocks were turned to release the assembly. Al Zim has the 356 assembly video in his collection, and they show it clearly. But it is on old 8mm movie film, so no posting it here. |
914Sixer |
Mar 23 2010, 06:49 AM
Mine has two factory holes that had rubber plugs. Pictures later.
ME733 |
Mar 23 2010, 07:10 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
....good grief....All you so called 914 experts are wrong...what dummies...the expert porsche engineers make provisions for everything....Here,s what the hole is for...SO YOU can DUMP your DOOBIE before the cops pull you over..... (IMG:style_emoticons/default/biggrin.gif) ...and you thought you knew it all. (IMG:style_emoticons/default/biggrin.gif) .
Mar 23 2010, 11:28 AM
As far as i know, every 914 had that tiny hole in the floorpan right there.
About the size of a M8 bolt ... (IMG:style_emoticons/default/shades.gif) Andy |
914Sixer |
Mar 23 2010, 01:22 PM
Picture of 72 floor with two factory holes that I removed the rubber plugs.
Lo-Fi Version | Time is now: 17th May 2024 - 02:59 AM |
