| Mr.242 |
Mar 24 2010, 06:45 PM
May your glass be smaller so it's always FULL! ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 10-June 08 From: Seattle Member No.: 9,160 Region Association: Pacific Northwest |
So here is my current state of my battery tray. I have removed the motor and I'm cleaning the bay to have it painted; hopefully soon!
![]() I have agreed to purchase a battery tray and support, and I see this new install and I wonder what options I have. Here's GA1142's recent post: ![]() I was wondering what people have done to mount their tray. I was told of by my body man of the option of using "rivet nuts" so I can unbolt the tray and support to clean up under the tray. Looking for some .02 cents on the topic. It's being done on a real SIX, but not for concours status. For DE, AutoX, and beat my bro! Thanks.....ping away with ideas. |
| r_towle |
Mar 24 2010, 07:20 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
If the lower support is seam welded, and you bolt the top tray to both the inner fender and the lower support, I would certainly do it with the rivnuts.
I weld them in, but next time I get my engine out, I plan on doing the same type of removable install so I can clean that area better. Rich |
| sww914 |
Mar 24 2010, 07:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
You must be sure that the tray is flat where the battery sits. If the battery is riding on bolt heads they will wear through the bottom of the battery and make an acidic mess.
| agentblr |
Mar 24 2010, 07:33 PM
Member ![]() ![]() Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 |
Do the right thing.....mount your battery in the rear trunk. Where they should have put it in the first place!
| qa1142 |
Mar 24 2010, 07:54 PM
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Weld it in right. (IMG:style_emoticons/default/welder.gif)
I drilled holes where each spot weld should have been and filled it with my mig. With engine out, I had Brad clean up that work and make it look good Do it right |
| Eric_Shea |
Mar 24 2010, 09:12 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Do the right thing and weld it in where it's suppose to be... it's an original -6. (IMG:style_emoticons/default/slap.gif)
| McMark |
Mar 24 2010, 09:33 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Weld it where it's supposed to go. They battery trays rusted out because of rain. Is your car going to live out in the rain?
--AND-- Why would anyone sacrifice trunk space, when the battery's got a perfectly good home in the engine bay. --AND-- I wouldn't trust a riv nut to hold a heavy battery being tossed around under spirited driving. You're just asking for that battery to jump loose and crack into a carb. Yikes! --AND-- (IMG:style_emoticons/default/cool.gif) |
| jgara962 |
Mar 24 2010, 09:47 PM
Yo, this is how I roll ![]() ![]() ![]() Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
I had to have McMark weld a new tray in for me. The old one was held with rivets and failed on the way to the WCR autox a few years ago. What a dissapointment not being able to run because of a poor fix. Welding it in is the only way to go.
| jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I wouldn't trust a riv nut to hold a heavy battery being tossed around under spirited driving. You're just asking for that battery to jump loose and crack into a carb. Yikes! (IMG:style_emoticons/default/agree.gif) Riv nuts are far from structural. I only use them on access panels or other light weight stuff. In that area I wouldn't be surprised if they spin on you when you try to loosen the bolt. Ever try and drill out a spinning riv nut? BTDT. It blows. |
| SirAndy |
Mar 24 2010, 09:55 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,562 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| Mr.242 |
Mar 24 2010, 10:37 PM
Do the right thing and weld it in where it's suppose to be... it's an original -6. (IMG:style_emoticons/default/slap.gif) What the hell....I got a whack in the back of the head?? (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/blink.gif) Even though I live in Seattle, it will not live in the rain. Thanks for the input. Love the facts that come from other peeps trials and FAILS. Will weld it in....... (IMG:style_emoticons/default/welder.gif) Thanks everyone! I will keep you posted..... |
| Eric_Shea |
Mar 25 2010, 08:55 AM
It was a love tap. (IMG:style_emoticons/default/biggrin.gif)
Now... (IMG:style_emoticons/default/alfred.gif) |
| jonferns |
Mar 25 2010, 09:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States
Weld it in, its permanent and you won't have worry about it falling off. Here's mine, just painted the engine bay recently. ![]() |
| Root_Werks |
Mar 25 2010, 09:47 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,087 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Weld it in right. (IMG:style_emoticons/default/welder.gif) I drilled holes where each spot weld should have been and filled it with my mig. With engine out, I had Brad clean up that work and make it look good Do it right (IMG:style_emoticons/default/agree.gif) It doesn't take much to hold the two pieces in place very strongly. Drill a couple of holes in the two pieces, then 'tac' or fill the holes when you weld them to the car. Even 'tac' the tray to the support. The factory never bolted the two together. You have a six, keep it as original as possible. The cleaning and prep will take the longest. The 'tac' welding will take minutes. (IMG:style_emoticons/default/welder.gif) |
| jt914-6 |
Mar 25 2010, 11:45 AM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
On your original six, keep it in the stock location and use an Optima or other totally sealed battery. No acid to spill or rain spreading acid.... (IMG:style_emoticons/default/welder.gif)
Lo-Fi Version | Time is now: 9th November 2026 - 10:30 AM |
