Battery Relocation |
microsa |
Mar 29 2004, 06:27 PM
Member Group: Members Posts: 94 Joined: 20-February 03 From: San Antonio, Tx Member No.: 329 |
When the battery is moved to the front trunk, what is the preferred route to run the cables?
Thanks Mike Allen San Antonio, TX |
URY914 |
Mar 29 2004, 06:47 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,483 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Can I ask why are you moving it to the front trunk?
Is this a street car or race car? Paul |
microsa |
Mar 29 2004, 06:51 PM
Car is being used as primarily an Auto-x car. Trying to get the weight distribution closer to being balanced and clear up some space in the engine compartment.
URY914 |
Mar 29 2004, 07:03 PM
Check your rules, you may not be able to move it. You'll be adding some weight in the extra long cable also.
I put mine on the floor on the passenger's side which is about as low as possible. You'll need to put it in a plastic box. This way it is closer to the engine (less cable needed), is low and it offsets the driver's weight a little. In side to side weight balance. Paul |
microsa |
Mar 29 2004, 09:37 PM
Car is already in CS/P and is still street driven some so front trunk is the place. One cable from starter to battery dosen’t weight much and the battery is going to be mounted on the spare tire well floor. Oil cooler w/fan is going where the battery was located.
campbellcj |
Mar 29 2004, 11:14 PM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
You could also consider a lightweight battery. I have an Odyssey 680 ready to install; something like 11lb vs 35lb compared to an Optima IIRC, and no rewiring or rules issues...
dinomium |
Mar 30 2004, 01:28 AM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/wink.gif) If you are going to do it, I would use this next time: http://www.moroso.com/catalog/categorydisp...p?catcode=42001 It cost about 95 bucks plus wiring. The cleanest wiring I have seen is down the longs, follow your oil lines...
I have a box from West Marine that the PO used. It is flimsy plastic that doesnt fit a car battery and the tie downs are poopy! As for the rules, I now that SCCA and PCA will ding you for moving the battery in the lower two classes. Good luck and let us know how things go. Cheers, |
kenpolives |
Mar 30 2004, 03:59 AM
Member Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
This set up works great, you need to put a bar across the front trunk with a flat fray to set/mount the bat. on.
RON S. |
Mar 30 2004, 05:55 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,211 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
My idea follows along the same lines.
Down low,offset from centerline,suits me. Ron Attached image(s) |
TimMartin |
Mar 30 2004, 01:47 PM
Newbie Group: Members Posts: 45 Joined: 16-January 03 From: Morgan Hill, CA Member No.: 157 Region Association: None |
Here are a few pics of my front-trunk battery relocation.
http://talking-dog.com/914/23.html I made a bracket, and used the performance products relocation kit (which is completely generic). Since these photos i have tacked down the cable nicely and it looks very professional. I routed the wires down the rockers where the charcoal filter hoses used to go; i pulled one of them out since i don't have 'em hooked up anyway (6 conv with carbs.) All in all, i wouldn't have bought the relocation kit, since the tray didn't do that much for me. I could have gotten the cable from any good auto parts or electrical supply store, and the hardware to mount it could have all been fabricated and/or from the hardware store. I mounted it on the passenger side 1) because i don't normally have one, so weight distribution made sense and 2) i wanted to still be able to put the spare and floor in and out. |
Mueller |
Mar 30 2004, 01:53 PM
I took a different route.......I removed my original batter tray, rotated the battery 90°, and placed the battery down in the "hell-hole" area up against the firewall. Lower CG, keeps weight on the passanger side and I only had to increase the length of the negative wire a few inches.
If you are worried about weight, there is also aluminum wire as used by welders......... |
Scott Carlberg |
Mar 30 2004, 03:51 PM
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
QUOTE(campbellcj @ Mar 29 2004, 09:14 PM) You could also consider a lightweight battery. I have an Odyssey 680 ready to install; something like 11lb vs 35lb compared to an Optima IIRC, and no rewiring or rules issues... like this.... Attached image(s) |
Scott Carlberg |
Mar 30 2004, 03:53 PM
the install kit (at least from S-Car-Go) includes this install box...
URY914 |
Mar 30 2004, 07:06 PM
This one is small, light and cheap. Its a lawn mower battery. Cost under $40.
Lo-Fi Version | Time is now: 10th May 2024 - 01:56 AM |
