Third brake light, my easy solution |
Joe Owensby |
Mar 30 2010, 10:30 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
The photo shows my third brake light. I bought a unit from Sourhtern Rods, I think southernrods.com, for 20 or so dollars. It sticks onto the inside of the rear window with double sticky tape. I loosened the inside cockpit backpad and pulled it out enough to run the wires down behind the backpad. Didn't have to remove the engine compartment latch, as I only needed to access from the side to route the wires. Removing the center console between the seats allows access to the wire bundle, where I spliced into the wire that runs to the brake lights. I also added a ground attachment in this area. Looks pretty good. Does not restrict any rearward vision. I don't have any outside photos of it lit up, but it is very visible. The stuff you see outside the window belongs to my kayak carrier, see another post. Yes, I need to replace the top rollbar pad. I have one on a parts car but I can't get it off. JoeO
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 04:51 PM |
