Anyone in the Phoenix area who can fix tachs?, mine still isn't working |
buhs914 |
Mar 31 2010, 01:59 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
Ok so i did a full check to see why my tachometer stopped working and i can't figure it out. I believe it may be the tach itself and not the connections. Is there someone in the area who could take a look at it or something one of these days? thanks.
dr914@autoatlanta.com |
Mar 31 2010, 02:06 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Ok so i did a full check to see why my tachometer stopped working and i can't figure it out. I believe it may be the tach itself and not the connections. Is there someone in the area who could take a look at it or something one of these days? thanks. If you are sure that it is the tach that is bad send it to Palo Alto and to the attention of hartmut. He is really good and vdo factory authorized. |
buhs914 |
Mar 31 2010, 02:15 PM
Ok so i did a full check to see why my tachometer stopped working and i can't figure it out. I believe it may be the tach itself and not the connections. Is there someone in the area who could take a look at it or something one of these days? thanks. If you are sure that it is the tach that is bad send it to Palo Alto and to the attention of hartmut. He is really good and vdo factory authorized. Ok cool. The only problem is that i'm uber low on cash as a college student haha. I'll recheck my connections a few times to be sure. |
TheCabinetmaker |
Mar 31 2010, 02:30 PM
Can you hook it up to someones else's car to make sure? Used tachs are easy to come by.
They don't go bad very often. |
Tom_T |
Mar 31 2010, 02:49 PM
Ok so i did a full check to see why my tachometer stopped working and i can't figure it out. I believe it may be the tach itself and not the connections. Is there someone in the area who could take a look at it or something one of these days? thanks. If you are sure that it is the tach that is bad send it to Palo Alto and to the attention of hartmut. He is really good and vdo factory authorized. Also North Hollywood Speedo repairs them, but I agree with the others above - esp. on a student's budget - test in another car, check anything you may have changed & all connections & wiring for wear/cracked insulation/shorting-out, the maybe try to get an inexpensive used one for now & save your original one to restore at Palo Alto or N Hollywood when you're bucks-up! (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:10 PM |
